TIME SLIP DATABASE
new bests 8-23-06 PRP
Old Aug 25, 2006 | 10:27 AM
Quik's Avatar
5 year bitches!
Originally Posted by ap2002
hey quick what size tire are you running??? might have to drop tire size a little to get that 1.6??
28x11.50x15
im going to try a 26" tire for now till i can figure out if im swapping gears or not. right now im favoring the gear idea to bump up my RPM
Old Aug 25, 2006 | 10:29 AM
Quik's Avatar
5 year bitches!
Originally Posted by bluecajun5.3
great times dude
v8 and I's best 60' is 1.73. both were done on stock suspension with same tire setup.
i'm shooting for 1.6? myself.
i know your a reduced weight 5.3 how about V8? im pushing full street weight and what rpm are you crosing the traps and where does your cam supposly pull till?
i think mine is in the gearing right now, if you could post up a full slip if you have one
Old Aug 25, 2006 | 03:41 PM
bluecajun5.3's Avatar
11 Second Truck Club
FYI, v8 and i are pretty close to same race weight with our record times, (~4100).
i'm crossing the traps around 6k on a good day, and cam stops pulling at 6k. (see how it flatlines at 6k)
hopefully those 26" tall et streets will still benefit me with the ls6 intake swap and u/d pulleys.
here's the slip quick...
Old Aug 25, 2006 | 07:55 PM
speedy02's Avatar
Nice times! I cant make up my mind ether on what gears to get. What was the DA that day on the track?
Old Aug 25, 2006 | 11:09 PM
v8
17,16,15,14,13,12,11 Drvr
mine is a stripped down version too lol, take some weight off that heavy pig j/k, you would see another .5 drop in the 1/4.
oh yeah i'm traping at or close to 6k.
Old Aug 25, 2006 | 11:57 PM
Quik's Avatar
5 year bitches!
thanks man!!! i can see your peaking crossing traps so your where you need to be. im need of gear for my setup which should drop me drastically. im around 4600 for race weight. im a LS trim truck that now has full leather and leather on door panels that along with all my skirts steel wheels. aftermarket stereo setup and etc. i carry agood bit of weight. if i did a diet then yes but its my DD so i dont mind carring the weight.
see my cam pulls till 6400 they claim and alot of dyno sheets ppl see 6500 before it gets flat. i also have an issue with traction on the 1-2 shift
Old Aug 25, 2006 | 11:58 PM
Quik's Avatar
5 year bitches!
if you mean me? i have no clue probably wasnt good since it had dropped a few drops on us that day and you could smell rain in hte air later that night into morning it rained
Old Aug 26, 2006 | 12:00 AM
Quik's Avatar
5 year bitches!
yea i know about weight reduction but im not about to drop lbs street trim for my DD. if anything switch from my steel wheels to some ALIs
and 6k still wouldnt put me in where i need to be
Old Aug 26, 2006 | 12:32 AM
v8
well one thing about a DD is street tires, do you drive around with slicks all the time? If not then your not in a DD mod lol
I run mine with full weight somtimes as well, but we go to the track to see how fast we can go, either street form or drag truck form. It just makes sense to run your best at the track either way. Go for the fastest times you can get and run the fastest times in street trim. I know its not going to run what it does with all the weight gone but I do know what it will run on street trim and street tires. low 13's to high 12's in cold weather and 13.6@99 in hot weather.
I used to run my old truck at the track in full trim, just drop the tailgate, but it never gets your best times now does it lol.
either way have fun and glad your getting faster.
Old Aug 26, 2006 | 10:46 AM
rgvsierra's Avatar
good times, just for some comparisons, i've pulled a 1.72 on the 3:73's, 4:10's are up next, hoping for a 1.65 60ft.
