new best !!!
Nice time!!
He is adding more fuel with the nitrous,just running a leaner A/F than most do like on motor.
Even though he may run the same A/F on the bottle as motor,that does not mean he is not adding fuel,you have to add fuel with nitrous or it will go WAY lean.
I am running a custom dry kit from nitro dave and I run 1.20 on the pe multiplier on motor and 1.22 on the nitrous and its the same afr so adding fuel just not like most people say you shoud run 11.8 afr on nitrous i am running right around 12.6 to 12.8 no knock and running 22 degrees of timing and 32 degrees on motor.
The rest of the info is here http://smotherssupercars.com/nitrousclass.html
