TIME SLIP DATABASE
Launching/racing in 4X4?
Old May 23, 2010 | 10:40 AM
1LOW4X4's Avatar
Banned
Default Launching/racing in 4X4?
I've got a Z-71....lowered and all that...I'll have a built LS1 in this thing sooner or later and a built transmission, hope to be in the 12's motor and 11's w/spray. My question is for the guys who have 4x4....These may be some dumbass questions....
When you launch, its in 4 HI? After you get going, do you switch back into 2 wheel drive or ride 4 HI all the way down?
Is a good burnout necessary with 4x4? I've heard from some guys running tens that even with a good burnout the back wheels will spin...so I guess you should burn em down in 2 wheel drive just to get em sticky?
Any help would be appreciated lol
Old May 23, 2010 | 10:48 AM
DV2000NJ's Avatar
13 Second Truck Club
Do you have the manual, or push-button (autotrac) transfer case?
Old May 23, 2010 | 11:00 AM
1LOW4X4's Avatar
Banned
pushbutton
Old May 23, 2010 | 11:03 AM
DV2000NJ's Avatar
You lucky son of a bitch.
From what I hear, you'll be able to shift from 4hi to 2hi under power. I believe most guys shift out after the 1-2 shift.
I've got the manual t-case, which doesn't shift out under power, and I've had no problems running in 4wd all the way down the track.
Old May 23, 2010 | 11:30 AM
trever1t's Avatar
2nd fastest 5.3 ECSB
Dust off the rears, (depending on power level you'll need to adjust tire pressure) launch in 4hi, after the 1-2 shift attempt to shift back to 2wd. Some can and some can't. There are a number of threads on this subject, look around
Old May 23, 2010 | 12:05 PM
zeake's Avatar
Or convert to awd like I did.
Old May 23, 2010 | 01:29 PM
KDavis04ss's Avatar
yeah x2 ^
Old May 23, 2010 | 02:00 PM
1LOW4X4's Avatar
Banned
Na, I can't see any real advantages of switching to full
time awd over 4 wheel drive
Old May 24, 2010 | 02:02 PM
Jeteys5.3's Avatar
I've got the manual and it will shift out after second when i push it back up to 2wd
Old May 24, 2010 | 05:02 PM
DV2000NJ's Avatar
So my truck just sucks?
That's interesting though, you're the first one I've ever heard of with a manual t-case that shifts out under power.
