TIME SLIP DATABASE
got a 6.0
Old Oct 29, 2010 | 08:01 PM
fastjweb's Avatar
Default got a 6.0
found me a 06 lq4 with only 15,000 miles on it, came out of a wrecked 2500, then sat in a garage for a few years for a project that never happened. im planning on putting my same cam in that i have in my 5.3, oil pump, and basically all my other goodies including supercharger, and throwing in a circle d 3200, because i dont have a stall now. i ran a best of 13.40 at 94 with my 5.3, low mph because my full throttle 3-4 shift was set at 181mph, way off, so i couldnt shift and coast through the traps, i should have run a 13.1ish. what should i expect with the 6.0 and stall, with all my same mods. thanks
Old Oct 29, 2010 | 08:16 PM
iamkeniff's Avatar
12.7-12.8s
Old Oct 29, 2010 | 08:20 PM
fastjweb's Avatar
id be happy with that, but i figured it would do that with out a converter and that 6.0 swap. i guess will see.
Old Oct 29, 2010 | 08:26 PM
Beatdown Z's Avatar
Laid Back
Mid, maybe low 12's...
Old Oct 29, 2010 | 08:49 PM
iamkeniff's Avatar
oh yeah, i see a 3200 in the mod list lol i should read it before posting.
12.2-12.6s depending traction/weather. if your truck is anything like mine it doesnt like DRs anymore.
Old Oct 30, 2010 | 06:56 AM
custm2500's Avatar
Ph.D. in HUBRIS
The converter alone is good for .5 and probably a good deal more if you are going with a 3200. Don't forget on boost that converter should stall more like 3700 so you might want to look into a 3000 or so. Anyhow .5-.75 from the converter with your current setup.
The 6.0 is going to have 45ish more hp stock and respond better to the boost(if you can keep the same PSI) so going to say 60 ish hp over what you have now. If you don't drop a total of 1.2-1.5 off your current time i would be surprised!
P.S. All you guys running low 13s and 12s or better sure hurt my feelings. I felt special with a 13.4 slip and as the truck sits now should run a 12.99-13.1 when i make it to the track. It isn't so special with all you other guys doing the same or better!
GMCtrk
18
Oct 6, 2015 03:48 PM
turbo6c3
Oct 5, 2015 06:11 PM
Cammed4ever
Sep 30, 2015 03:38 PM
trevorh1
Sep 27, 2015 08:47 PM
sTNT971
Sep 26, 2015 04:22 PM
