Going back to Atco with the hemi
Ran my sons 2012 ram 1500 Hemi rcsb with 4.56's and B&G tune on the stock tires it ran 13.73@99 2.000 60' last sat. I thought it was good for the mods.ran with some fast chevy trucks (friends from here) they both hit high elevens.
Going back tommarow with a short drag radial and try for a 13.50
To much tq. Management and not enough rpm's it only goes to 5800.
Bone stock with 3.21 gears it ran 14.58@95
The 45RFE base transmissions are HORRIBLE. It had invalid ratio codes for 4th and 5th gear and after I romped on it, all I had was 1st and 2nd.
https://www.youtube.com/watch?v=wB4hk4flVAQ
Were you slipping off the line? I think thats a good time.
Anything that can run 13's with gears and tune only is impressive in my eyes. It would walk a SSS with the same mods I can tell you that much.
If i built it up of an idle it would spin.I dropped the tires down to 25 psi and just nailed it and it hooked
Who did the gear swap? I know with 4:56 the diff has to me machined for the gears for clearance issues.
Also ditch the BG tune. Put your 2011 computer back in it and get a CMR DIablo custom tune for it. Ive had both and the diablo is a much better solution for tuning
FlowmasterMufflers
Oct 26, 2015 06:19 PM
FlowmasterMufflers
Aug 14, 2015 01:04 PM
FlowmasterMufflers
Aug 14, 2015 12:47 PM
