Glide?
The trans in my truck has given me problems the last two summers the truck ran. It was redone buy the guy who built if for me originally but I hadn't run it much before pulling the motor.
My plan is if the 80e takes a crap soon to just jump to a glide. The truck will weigh around 3500 and make around 500 N/A, it is built for 350 of nitrous but I don't plan to run more then 150 for this year.
My question is will a glide slow me down since I am heavy compared to most cars the run them especially running the lower amounts of nitrous?
I am hoping that the 80e has had all it's gremlins worked out but rather keep an eye out then pass up a great deal if one comes along.
P.S. The truck will only occasionally see the street and will never go far unless it is on a trailer.
The glides are vary strong if they are built right, but its pretty much like taking off in 2 gear, id much rather go to a built th400, if you get one thats built right it will hold anything you could ever throw at it.
That is what I was thinking. My 80 is supposed to be indestructable in near stock form. It isn't breaking but was having electical problems, causing it to not shift correctly. I hope it will work just fine because I won't have the money to do anything right away.
3500#s is guess it might be closer to 3800# we will find out soon.
id go with a 400 in it. a glide is strong but your limited on your gearing, low and high. you can change low gear but its still only 1.8x:1 ratio which unless your running a 5500 stall is going to be a pig. if you were under 3000# then it may be different.
you could man up and drop a lenco in there. i hear the st1200 and cs1's arent horrible on the street and who wouldnt love rippin levers clutchless
Last time out my truck weighed 3,525 with me in it and a 4L80E. It made 449rwhp with the 4L80E and 521rwhp with the new 418ci motor. I have a 2 stage kit good to 400+ N20 hit.
I talked to 3 reputable tranny shops. All three of them told me I wasin the middle of either trans. The 400 would net me better 60's if I could keep it hooked but the glide would net me a better mph. They all felt the ET would be very close. They all also agree that as weight went down, the glide would be the better trans.
They all said I needed to stall up going with the glide.
You have to remember, the N20 is going to give you a lot of TQ to get it moving.
I know weight it my biggest factor.
I hope and pray that the 80e is ready to take a woopin because I will not have the money for any trans swap/work soon.
I will see what weight is once I get her rolling again then cross my fingers I don't have to worry about a trans right now.
