TIME SLIP DATABASE
which front coil spring to transfer more weight
Old Jun 17, 2009 | 11:26 AM
  #21
Tootall's Avatar
what if you dropped your rear more, or made it more level?
There's sway bar disconnects, and sliders for the end links.
Old Jun 17, 2009 | 12:05 PM
  #22
TXsilverado's Avatar
i cant drop my rear end any more. i wish i could to level it out. its alredy on 3" drop shackles and 2" drop hangers. rear end sits about 1 inch higher than the front.
thought about calling up calvert for some mono leafs.
Old Jun 17, 2009 | 12:40 PM
  #23
Tootall's Avatar
do you have the over load spring in there still ?
Old Jun 17, 2009 | 12:48 PM
  #24
nope...
Old Jun 17, 2009 | 01:05 PM
  #25
Tootall's Avatar
So I'm guessing a c-notch is out of the question. The half plate instead of the full cut.
Old Jun 17, 2009 | 02:10 PM
  #26
no need for a notch. im not hitting the frame. unless your suggesting a flip kit.
Old Jun 23, 2009 | 07:00 PM
  #27
1slow01Z71's Avatar
Tin Foil Hat Wearin' Fool
If you arent hitting the frame with a 5" drop, then it sounds like you need to get the rear end to squat better...
Old Jun 23, 2009 | 08:53 PM
  #28
95 bright teal's Avatar
I have 4"of drop i the rear and am setting down on button bumpstops daily. I have one inch of measured rake(3/4).
I would think with your setu-p you would be level or very close to it, what brand are the drop components?
Oh and i removed the swaybar a few months ago and the weight transfer is great
Old Jun 23, 2009 | 11:08 PM
  #29
i dont think its a 5" drop on the rear...i dont know...it just sticks up in the *** end.
now im thinking about putting on a flip kit with the stock setup and putting in a 1" lift shackle. that should get me ALL of my squat back huh?
Old Jun 23, 2009 | 11:09 PM
  #30
well i dont know what im doing wrong. my *** end wont squat at all.
belltech hangers, stock springs with overload removed, belltech 3" drop shackles, djm front springs, 90/10 shocks up front, rancho 9000 adjustables out back. i never touch the bump stops unless i SLAM into something.
