TIME SLIP DATABASE
Front Coil Overs? and roll cage? NEED SOME INFO
Old Aug 16, 2011 | 09:05 PM
denali_on_26's's Avatar
From: Where our street cars are faster than your racecars..Mississippi
Exclamation Front Coil Overs? and roll cage? NEED SOME INFO
does anyone know a set of coilovers that will for the 2001 silverado? even a set that can be "made" to work?
if not what about a "trick" spring and an adjustable shock?
also has anyone tried the Roll Cage for Jegs? it says c10 up tp 2005 model?
i am getting close and these are a few things i am questioning
Old Aug 17, 2011 | 11:38 PM
Eric67's Avatar
Don't do the Jegs cage Iv cut several out there junk in my option.
Old Aug 18, 2011 | 01:34 PM
What would you recommend?
Old Aug 18, 2011 | 01:41 PM
Phantom's Avatar
11 Second Club
By the time you buy a junk cage that doesn't fit well and try to weld it in, then have to pay a good, local chassis shop to cut the old one out and bend you up a good one, its cheaper to just hit the local chassis shop up first
Old Aug 18, 2011 | 08:55 PM
thats the problem...no local chassis shop
anyone have a way they have done front coilovers?
Old Aug 18, 2011 | 08:56 PM
Phantom's Avatar
11 Second Club
It would be worth your time to find one near you and have them do your cage.
Coil overs should be a problem. I think flaco has them on lil sis and spike has them on his truck i believe. Would just need to get the right height and spring rate
5.3Okasai
Mar 9, 2022 01:07 PM
signguy62
Sep 20, 2015 02:05 PM
GM1697
Sep 11, 2015 10:19 PM
gtyler04
Jul 28, 2015 06:21 PM
