TIME SLIP DATABASE
First passes :(
Old Dec 13, 2008 | 01:43 AM
  #21
stock48's Avatar
9 Second Truck Club
Originally Posted by GMCDee
Im using the 42lbs injectors now.
Still on the big side. Where did you run the truck?
Old Dec 13, 2008 | 09:53 AM
  #22
GMCDee's Avatar
I ran it in Vegas nice weather and good track was probably around 65 out.
Old Dec 13, 2008 | 10:07 AM
  #23
ZO6Ted's Avatar
Don't worry about your setup being bad, just stick with it untill you find the culprit. I know its frustrating but you're basic combo will be a runner when your figure it out. No need to switch trucks.
Old Dec 13, 2008 | 10:57 AM
  #24
95 bright teal's Avatar
Chris and Aaron use EFIlive I think that will be your best option especially when the turbo goes in
Old Dec 13, 2008 | 11:25 AM
  #25
00Silv4.8's Avatar
Yeah, I believe AJ and NicD are the only who use HP Tuners really. Even Blackbear (what Aaron uses) is thru EFI Live.
Old Dec 13, 2008 | 12:50 PM
  #26
stock48's Avatar
9 Second Truck Club
Vegas is an altitude track about .5 slower than sea level on a NA setup. I have watched 427CI LS7 vetts run mid 12's there with slicks. You need to get an AFR gauge, EFI, or HP so you can log some runs. Then you can send them to your tuner so he can see what's going on.
Old Dec 13, 2008 | 01:23 PM
  #27
kbracing96's Avatar
Ya, you need to come down and run at Speed World.
I can hook you up with EFILive, just let me know.
Old Dec 13, 2008 | 02:25 PM
  #28
vanillagorilla's Avatar
Your abs/p-brake lights sound like wheatly entered in the wrong gears for your tune. Did you ever find out for sure what gears you have? Is your SES light on at all?
If you want to run it here at SIR, I'll log it for you anytime. We can see what's up with your tune. Your combo won't get a 13 here in Tucson, even in cold weather, but 85mph is worse than what my stock 4.8 did in at SIR with I/E/e-fans. Even on the coldest nights the DA is still above 3000ft. Get a wideband too before you get too upset. In my mail order tune days, things ran really rough.
Old Dec 13, 2008 | 07:41 PM
  #29
zippy's Avatar
If I had to guess from looking at those times I'd say you were in the low octane table with hardly any timing. Even with a stock cam you should be stretching towards 13's.
Old Dec 13, 2008 | 07:50 PM
  #30
00Silv4.8's Avatar
since when are you coming back to AZ traitor!?
