First 99-up Fullsize GM truck in the 9's!!
#53
Originally Posted by blacksheep
Thats only on 200. The motor is just a basic 10.5:1 408 with ported 317 heads. On a 200shot it made 715hp and on motor it makes around 500hp. Mr Marine, the front end has plenty of travel but that's as high as it will pick up the front end.
#54
Originally Posted by Quik
you mind posting cam specs if not i understand, also what header size you using and what size exhaust
#55
The cam is around a 240/244 .615 , headers are 1 3/4 ASM's and exhaust is a 4" Flowmaster.
#56
what rpm you turning? also what gear do you ahve and what size slicks you running also waht trans
#57
I shift at 6800 with 4.10 gears, 31" slick and a th400.
#58
whats the setup run NA? also what rpms you turning in the traps on the juice when going 130
