Fastest XR265 cammed 4.8/5.3/6.0 trucks?
awesome! Whats your set-up for the track.....you run exaaaaactly the range that I am looking for...low 13's with a little over 100mph.....
*is your truck a regular cab?
*whats your stall speed?
*what gears..410 or 373's?
*are the heads untouched besides a set of good springs?
*are you using the stock 5.3 intake manifold untouched?
*are you running long tubes? How big are the primary's and do you run cats?
sorry about the TON of questions....you just have exactly what I'm looking for...
that's pretty quick for an extended cab with 342's! I just hope that the shorties don't KILL me as far as power....I don't think that there is much that I can do to re-coupe the amount of power lost by still running a stock like short manifold.....I wonder if it would just loose a LITTLE top end and then KEEP the bottom end of the power band....what do you guys think?
Last september at Famoso, I ran a 14.7 @ 95, 60' was about 2.33, DA was around 1700. My truck weighs around 4250lbs no driver. TB stall and 3.73 gears are holding me back, I think. It did a 13.03 @ 107 with the bottle, though.
Suburban2500
07-19-2015 04:50 PM
