TIME SLIP DATABASE
fast lightning
Old Jan 14, 2007 | 03:49 PM
  #21
FURO's Avatar
Originally Posted by Frank02L
Looks like that tailwind was affecting the beams a little bit. I've had my burnout smoke do that before.
I bet you are stuck with 16s on that rear brake setup too arent you?
That thing launches hard. What are you guys going to do for a built 5R110?
The truck came with 17`s we had Bogart Racing Wheels make some Custom 16`s for it an they are beautful.
For the trans that is up in the air at this point.
Old Jan 14, 2007 | 08:10 PM
  #22
Frank02L's Avatar
Too bad you can't go to 15s for the tire selection. Although it doesnt look like you guys are having the tires 'paw' as much as I have been having.
I know my truck (f250) wont fit 16s "normally"... I would think the brakes are very key to helping that truck launch.
Old Jan 14, 2007 | 11:03 PM
  #23
Ice-Monkey's Avatar
I think the 16" tires I have are the ticket now. Would've been way cheaper with 15's for sure.
If I would have had just another day out of the trans, I think the 1.40 would have happened. I was still a bit gun-shy on the launch, being the week before it twisted off a yoke on the line.
Spring can't come soon enough.
Old Jan 15, 2007 | 07:31 AM
  #24
Frank02L's Avatar
I hear ya on that last part! You could do like me, just travel south until you find a track open. Thats what I'm going to do on 1/27. Its about 3.5hrs for me but it'd be probably 1000 miles for you just to get here. haha
What DS are you running? The shaft has a 4 bolt flange on the front and rear doesnt it? With the slip yoke in the middle of the shaft?
Old Jan 15, 2007 | 08:40 AM
  #25
FMOS Racing's Avatar
Ah, that wonderful, "What's the next weak link" thing!
How do you build boost at the line? I started experimenting with a two step last year, and that's obviously not an option for you and the timing controls I'm adding for this year aren't either. I wouldn't think there's a 'brake available for your transmission either (I'm leaving off a foot brake with a big 3000 rpm stall converter).
Hope you come to the WFC! "Snow White" needs a little competition.
Old Jan 15, 2007 | 09:04 AM
  #26
Dbl G's Avatar
Way too hang it out there Frank,,,,
Old Jan 15, 2007 | 12:33 PM
  #27
McRat's Avatar
Congrats! There certainly are some wicked Lightnings out there. We wanted to buy one except we needed seating for 5 at the time.
Old Jan 16, 2007 | 08:14 AM
  #28
Ice-Monkey's Avatar
Plan on seeing me at WFC this year.
I've only left on about 18-20 lbs. so far. The brakes will hold maybe 30 lbs., so it's got more left. Need to change the exhaust so the starting beams don't get fouled by the smoke. But I'm not into "stacks"......
Old Jan 16, 2007 | 08:18 AM
  #29
Ice-Monkey's Avatar
Just a one piece 4" chromoly, with the rear 4 bolt flange. Went to bigger bolts.
Old Jan 16, 2007 | 06:34 PM
  #30
Frank02L's Avatar
Where did you get the CM shaft from? I have a 4" aluminum shaft but I'm somewhat concerned with it.
Cant wait to check out the truck at WFC! I Love some fast oil burners!
