Farmtruck goes 10.73 tongiht
#21
Truck weighed 3,650 last night with me in it and a full tank of gas.
347ci
11-1cr
5-6year old ported 853 casting heads (Absolute Speed, no longer in business I think)..
Trex cam
Crane 832 springs that need to be changed in a major way (My solution, a 418ci motor)
Super Victor with a 4150 to dominator adapter and Dominator TB
Edelbrock 1 3/4 stepped to 1 7/8 with high velocity merge collectors
Electric Water Pump
Alternator is the onlything running off the crank
Stock 4L80E
4,500ish verter
4.56's 315/60/15 ET drag radial
347ci
11-1cr
Trex cam
Electric Water Pump
Stock 4L80E
4,500ish verter
Where did you get your headers? Think they would work in my 68? Fixing to do an LS swap in it as well.
#22
Check out 67-72chevytrucks.com.. There is an LS1 swap section in under the engine drivetrain section. There are some different motor mounts that have been talked about, one set in which you can place the motor further back. If you used them, you could probably use the same headers. They are 4rth gen F-body Edelbrocks.
jrmchevyman
03-22-2012 05:54 PM
WheelsUp84z
11-14-2011 12:26 AM
