TIME SLIP DATABASE
Drag radials
Old Mar 14, 2010 | 11:28 PM
Default Drag radials
I have a set of 17inch stock escalade rims that I planned on using as a drag setup. I'm looking for suggestions on which ones to get. Also how wide can you go on these rims? How tall should I go? Heres two that I'm looking at...
http://www.summitracing.com/parts/MTT-3745R/
http://www.summitracing.com/parts/MNH-ROD06/
Old Mar 14, 2010 | 11:44 PM
max1's Avatar
Banned
how wide is that rim, if its 7.5 that widest you can go is 275 .
Old Mar 14, 2010 | 11:59 PM
Ya its a 7.5 so I'll most likely go with the M&H dr. Does anyone have any experience with that brand?
Old Mar 15, 2010 | 12:02 AM
max1's Avatar
Banned
- are you going full slick or drag radial.
Old Mar 15, 2010 | 12:11 AM
drag radial
Old Mar 15, 2010 | 12:18 AM
NORCAL TBSS's Avatar
Restricted User
GO with mts all the way. I did a 1.62 on a 50 shot on my wifes tbss with 295 45 17.
i would go with a short tire 275 40 17 mt drag radial would be best for you so you will be well in the powerband goin thru the traps. if you get a tall tire you will prob be barly into 3rd.
Old Mar 15, 2010 | 12:38 AM
Thanks for the suggestion Tony, I'll probably end up going with those. I'd just have to go with a shorter tire up front too, or have my truck lean back. Btw are you gonna bring the silver one out soon?
Old Mar 15, 2010 | 12:47 AM
Restricted User
yah at pinks in sept. I allready raced my wifes tbss and beat it 4 times and her truck ran 11.9. I had at least 6-7 car lengths at 120 when i shut down.
Old Mar 15, 2010 | 12:52 AM
Nice. Sounds like you should be deep into the 11's when you do take it to the track. You ever thought about a cam/Lts on your wifes tbss?
Old Mar 15, 2010 | 01:01 AM
Restricted User
nah keepin it a sleeper. im doing a ported intake manifold and 4 inch cold air intake set up next thats alll.
the adm 3 inch y pipe and the magnalfow muffler flow more than good for what i need it to do.
