TIME SLIP DATABASE
drag racing my truck...
Old Feb 17, 2009 | 10:53 PM
chevyz7120's Avatar
i tested it on my 99 z71 wich has 3:73 gears and nothing made a difference except tow haul that slowed my time down in the 1/8th mile drag....manually shifting through gears helped me out a bit but your not always accurate
Old Feb 18, 2009 | 10:42 AM
kbracing96's Avatar
Again, with stock programing and no shift kit, manually shifting will gain you nothing, because when it reaches the commanded shift point in the PCM, it will shift the truck whether you move the shift leaver or not.
Old Feb 18, 2009 | 09:20 PM
litreddevil's Avatar
Banned
Originally Posted by kbracing96
With stock programing the truck will not shift into OD at WOT, so 3rd or drive makes no difference. I would also not run in tow/haul. It does have more line pressure for the shifts, but it also shifts at lower rpm when WOT then out of tow/haul.
i was about to type the samething then read ur post
Old Feb 18, 2009 | 09:25 PM
Banned
i don't know about this cause a stock tune is 5700 are 5800 i could hold mine to the 6000 rev in all gears and that is why i put a shift light so i could shift it as close to 6000 as possible
Wolftrk99
Dec 3, 2015 08:12 PM
nabozny21
Oct 17, 2015 07:47 PM
turbo6c3
Oct 5, 2015 06:11 PM
BlownHD
Oct 3, 2015 12:24 PM
Slammed silverado
Sep 28, 2015 06:14 PM
