TIME SLIP DATABASE
Damn 10s so close with the 4.8
Old Apr 29, 2010 | 07:48 AM
RedHotRodTruck's Avatar
Awesome truck....10's or no 10's quit and accomplisment.
Old Apr 29, 2010 | 07:51 AM
impressive...
Old Apr 29, 2010 | 08:08 AM
stock48's Avatar
9 Second Truck Club
Originally Posted by quicksilverado
Get a two-step. It will drop your 60' and you're there.
Whats the deal with the 2step? Will it work off the foot brake? And how does it wire up?
Old Apr 29, 2010 | 08:27 AM
charcold-bowtie's Avatar
And yeah the two step activates when the brake is pressed, basically cuts cylinders individually to load the motor as well as other features. I think lingenfelter makes one that is near plug and play
I know he's on one, that was an update he did. Although you cant hear it.
youtube
Old Apr 29, 2010 | 08:46 AM
Llaverito's Avatar
I tried the 2 step but had no luck with it, the would bog and sputter even letting go the tran brake and 2 step button. Im shure it's just a matter of tweaking evertyhing and testing it out but the track is 1 1/2 drive to then the same back so I cant make it every track day.
Old Apr 29, 2010 | 08:50 AM
LsxCody's Avatar
Great time out of that lil motor
Old Apr 29, 2010 | 08:53 AM
GMCtrk's Avatar
Turbo is the way to go. Killer time.
Old Apr 29, 2010 | 09:58 AM
Casey2323's Avatar
how much boost/rpm do you leave with? what gear/tire setup?...
Old Apr 29, 2010 | 10:58 AM
quicksilverado's Avatar
Sounds like the two-step is not releasing as soon as you let off the brake. Try just the two-step. I do 1.5x 60' times at 3000 rpm setting. I'm sure I could leave at a higher rpm, but I don't won't to break anything.
Old Apr 29, 2010 | 11:14 AM
Havok2's Avatar
11 Second Club
and that 4.8 is the motor you didnt want? lol
good times bish.
