TIME SLIP DATABASE
cant figure this truck out . HELP
Old Jul 13, 2008 | 01:25 AM
charcold-bowtie's Avatar
do realize, it is built into every good tune, that when the IAT get up around 100 degrees, the tune begins to pull timing. At 100 it is around 3 degree then ramps up from there. A heatsoaked truck can pull timing pretty easily. Especially with a MAF that has a slow reading IAT sensor. Ive never even had a 60 foot better than 2.2 booo. thats with 4.10 and stall. But im in texas. Turbo 60 foot times will come later.
Old Jul 13, 2008 | 02:44 AM
Cuerva's Avatar
11 Second Truck Club
1.94 is still high for 85 deg weather. I used to get 1.80-1.81 in 90+ deg weather on my 5.3 on 28's.. I think you need to try a 3400 9.5" PI Converter, preferrably a multidisk since you have nitrous.
Old Jul 13, 2008 | 03:06 AM
adrenalinep's Avatar
I would try 26" drag radials or et streets or go to some 4:10s. Either one would drop it some imo with your current set-up . The 4:10 and 3800 stall would drop it for sure .
Old Jul 13, 2008 | 12:31 PM
ZO6Ted's Avatar
That cam probably doesn't make enough power down low. I think a higher stall and gears or shorter tires would help alot. Can you run more timing?
Old Jul 13, 2008 | 01:23 PM
ap2002's Avatar
Originally Posted by RickLowpez
so at 80 ur at 2400 or so?
i believe so, i could go for a ride and verify but truck is broke down..
dont get too desperate rick, wait for good weather before you change anything, except like going to 4.10's, thats always a good mod for some better e/t.s
Old Jul 14, 2008 | 01:25 AM
stock48's Avatar
9 Second Truck Club
well 85 deg.weather,08 rcsb gmc 91oct tune. full bolt on 220 high lift cam , 3500( break stall 3200) edge converter,373s, 28 m/t and only a 1.94 60ft. but went 13.35 at 103.6 mph. all night 103 mph so i was happy on that but not the 60ft. i tried different rpms also but nothing worked . so do i need 410 gears? bigger stall? what could it be? need suggestions asap
Famoso is a shitty track, the DA there is high for the physical elevation, and all the **** in the air kills power. Make a trip up to Sac you will run faster. We pick up at least .2-.25 tenths on a 10 sec car up there, you could gain even more than that.
Old Jul 14, 2008 | 06:58 AM
zippy's Avatar
You need to get a log of this happening. I'd bet you're having an issue with either power enrichment not coming in soon enough or a torque management issue. Could be the power hop setting, stall speed setting, etc, etc. With so many torque management settings in these newer trucks any one of those missed could cause that problem. I doubt a lack of torque from the cam would cause a problem with a 3000+ stall converter. Even in that weather I'd have expected to see around a 1.88 or so. I'd guess 1.7's in good weather with that truck.
Old Jul 14, 2008 | 12:05 PM
RickLowpez's Avatar
yup im gonna have 2 wait till good weather
wrb002
Aug 31, 2015 12:00 PM
black6spdz
Jul 16, 2015 01:32 AM
4B11T
Jul 13, 2015 03:48 PM
Nimoryan
Jul 5, 2015 03:50 PM
