Cant break into the 12's.
I can't seem to hook worth a shit after installing my 4.10's. The best 60' time I could get was a 1.95.
60" 1.95 1/8 8.3 @ 82.4 mph 1/4 13.17 @ 102.0 mph I had plans for a TR 220 and a Vig 3400 next but that won't be going in untill get better 60" with my current set up. My best run with 3.73 was: 13.09 @ 101.21 With a 60" of 1.87 |
Is this on street tires,slicks or drag radials?
ET Streets 26X11.5X16
damn file i thought u would have been in the 12's for sure, good luck i can se them 12's in a future though
Damn, tought you would hit 12s with the 4.10s last night. Don't worry, you'll dip into the 12s soon, just need to get the tires to hook off the line. :)
I was thinking... maybe with the 4.10s, a taller tire might help you get better traction... something like a 28X11.5X16? Also, are you using VHT Trackbite? If not, that might also help some. Anyways, your truck has the potential to hit 12s just a matter of finding a way to make them tires stick. You'll get the hang of it. :judge: btw, were you running with the caltracs on or off the truck? Good luck Tib. :) |
Thanks... This was without the caltracs.
Good luck Tib. :) |
what air pressure? i woulda tried dropping it till they hooked
14 psi
hey tib i run my et streets at 27psi and have no problem getting traction, start at 28 psi and drop to 24 to see what your best 60' is then. later.
Put the caltracs back on, play with the air pressure in the tires as stated above and remove the front sway bar if you havent allready and 12's will be yours :)
