TIME SLIP DATABASE
Boost+Nitrous/ 4.8L in-truck GoPro 1080P
Old 02-13-2011, 11:26 PM
foose04's Avatar
Default Boost+Nitrous/ 4.8L in-truck GoPro 1080P
Well... I still own a 11 second truck... no 10s for me...
Setup tonight was 76mm at 15psi with 50 shot. Got two runs, first run the wideband error'ed out so HPtuners did not trigger the spray, only extra fuel so I was pig rich. Second run was clean.
However, I've come to another wall. The extra HP from the nitrous eats up my transmission setup. I need help though, is this converter slip or transmission slip?
I run a built 4l80E built by CKperformance rated at 1000HP and a circle D 9.75inch triple disk converter stall speed of 3200-3400 but is easy to footbrake to 3700-3800.
Truck drops about 700-800 rpms between shifts but within .5 second its right where it was in RPMS before the shift. Nitrous run I was in second gear for 1.9 seconds, 3rd gear for 7 second, 6 of those seconds between 6100-6200 rpms. Like I said it seems with more HP it gets worse and also just seems to be getting worse anyways. Trans temps have never been over 200, usually around 150-160.
Here's couple clips showing how it shifts different with less power and then on the clean run. If you have high speed, select 1080p to see the tach better and full screen that sucker. GoPro Hero is the ****.
Also beat up 2011 camaro with a 175 shot. It was damn close though.
http://www.youtube.com/watch?v=HzFUuCJJOl0&hd=1
http://www.youtube.com/watch?v=aObU1C3yMAg&hd=1
http://www.youtube.com/watch?v=6L7G8azIIOw
Old 02-14-2011, 12:04 AM
chevyboy.520's Avatar
Those are some good runs! So close to hitting 10's get your tranny situation figured out and it will happen
Old 02-14-2011, 12:37 AM
9 Second Truck Club
stock48's Avatar
Hopefully a restal will help but the converter might be too small. My 10.5'' does the same thing when I run the pt88. Rpm never drops below 6300RPM after launch, and hits the 6800 limiter on the 1~2 shift no matter what I do. Yank said it's costing me big...
Old 02-14-2011, 01:00 AM
Mod with training wheels
smokeshow's Avatar
I will have me one of those cameras! Sucks you didn't break into the 10s, but sweet videos nonetheless
Is it a multidisc converter? You might benefit from a WOT lockup if it is...
Old 02-14-2011, 02:34 AM
BadAssChevy327's Avatar
ya why not try locking that thing up
Old 02-14-2011, 07:16 AM
9 Second Truck Club
tarinitup's Avatar
I should get my converter this week and will post up results going from 9.5 inch 3600 to 10.5 3200 yank. I we are blowing through converter.
Old 02-14-2011, 07:30 AM
quicksilverado's Avatar
You are blowing thru the converter.
Old 02-14-2011, 07:48 AM
RedHotRodTruck's Avatar
Nice runs...Love the camera in the cab!!!
Old 02-14-2011, 08:33 AM
sureshot's Avatar
Your truck hauls *** man! You'll definitely hit 10's with your setup!
Old 02-14-2011, 10:59 AM
BigKID's Avatar
Nice vids! (but I only watched to 480 here at work) I used my Go-Pro for the first time at the track yesterday but haven't downloaded the vids yet. Question though, what attachment did you use to get the angle from the back glass? My suction cup only has one mount which puts the camera perpendicular to the suction cup.
Quick Reply: Boost+Nitrous/ 4.8L in-truck GoPro 1080P
