TIME SLIP DATABASE
Bolt on 5.7 Hemi goes 13.08! N/A
Old Mar 6, 2007 | 06:15 PM
  #21
99Silverado5.3's Avatar
Yeah, IIRC there's also a guy running 13.3@100 with boltons and 6.1 hemi cam, but 13.08 with those mods is really impressive n/a, is it an 03?
Old Mar 6, 2007 | 06:22 PM
  #22
bigbadwolf54's Avatar
13 Second Truck Club
damn good times....If someone ever gets some tuning software out for the hemi us bowtie boys may have to quit ragging on them so much.... well maybe
It's all in good fun...
Old Mar 6, 2007 | 06:56 PM
  #23
Motorider228's Avatar
Originally Posted by slowprocess
That's really good times, man! That would really take the wind out of my sails if I were the guy in the thread below that ownes the stroked 370 hemi running 12.7.
He just needs to find his groove and he will run much faster than that. He may not be as good of a driver as rdhemi so that can attest to alot of it. How about all the supercharged chevy and SS guys running mid 12's? I think it should take the wind out of their sails too. Or any lightning guy for that matter. I have never heard of a stock L going 13.08.
Old Mar 6, 2007 | 06:58 PM
  #24
Derek @ EDO's Avatar
FormerVendor
good times.
how much weight was removed?
Old Mar 6, 2007 | 07:19 PM
  #25
rdhemi345's Avatar
Its still the stock stall and its an 04.
dlh2006-I pulled passenger seat, center console, gate, spare, and swaybar. My weight should be around 4500lbs.
Old Mar 6, 2007 | 07:22 PM
  #26
rdhemi345's Avatar
Track form....
Old Mar 6, 2007 | 08:43 PM
  #27
FormerVendor
cool, now Gary needs to do that lol and he needs some gears
then you two would be a good race!
Old Mar 6, 2007 | 08:44 PM
  #28
Toe's Avatar
Toe
Tailegate is about 60lbs. Spare is 82lbs if your stock tires were the 20's. Sway bar if stock is a good 60lbs. Not sure about the seat/centre console but there's probably another 100lb's between the two. These trucks weigh 4750lbs fresh off the train when equiped with the 20's.
Those small tires look dam goofy, but they get the job done. You probably dropping nearly 40lb's per tire going from the 20's to those. Now you need a stall and a comp 260 cam or something, you should run what Brad has run with the 370 stroker.
Brad will get way faster, that 12.7 run was his first, he was spinning a lot out of the hole and is still working out the bugs. He didn't have anywhere as nice of a DA as rdhemi345 had.
Old Mar 6, 2007 | 09:49 PM
  #29
rdhemi345's Avatar
Yeah, as soon as Gary gets those 4:10's, ls, and does some weight reduction he will be right there with me!!
Toe- When I do install a cam I hope to be 12.4's or better.
Old Mar 6, 2007 | 10:16 PM
  #30
If I were you I would get a cam, torque converter 4.10's and an auburn. The mopar posi isn't near as good.
