TIME SLIP DATABASE
Balls to the wall for SAR meet
Old Feb 3, 2009 | 07:09 AM
  #21
Wilde Racing's Avatar
How do I change this text
Originally Posted by Flaco
on race fuel since the burn rate is faster you have to add a certain % of fuel across the board
I think you mean slower....
Old Feb 3, 2009 | 11:26 AM
  #22
zippy's Avatar
It's not uncommon when using race fuel to have a rich condition due to today's fuels. Most pump gas has 10% ethanol in it, race fuel should be straight gas.
Old Feb 3, 2009 | 12:11 PM
  #23
Flaco's Avatar
8 Second Club
True, true
on some, yes..depends which octane u use.. I use Q16 sometimes and have to add more fuel to compensate
Old Feb 8, 2009 | 10:10 PM
  #24
tarinitup's Avatar
9 Second Truck Club
Tried out the new set-up for the first time at the track. It is .43 and 4 mph faster in the 1/8 mile than my last set-up. Still not hooking up completely only 1.85 but slick was spinning on rim and my home track never preps right. The inline is coming out and will be replaced with dual intanks since fuel pressure dropped 6 psi during nitrous pass.
Old Feb 9, 2009 | 10:22 AM
  #25
Last Call's Avatar
TOTM: January 2007
What was your 1/8 mph et and mph?
Sounds promising!!
Old Feb 11, 2009 | 10:25 AM
  #26
vanillagorilla's Avatar
What's your full suspension setup? I'm curious as to why you're only pulling a 1.85 60ft with your combo and previous ET's. I doubt the slick was spinning on the rim if the track wasn't prepped.
Old Feb 11, 2009 | 12:15 PM
  #27
krambo's Avatar
Originally Posted by tarinitup
yeah and both pumps run at the same time.
Are both pumps on the same circuit? One pump may be not getting a full "12" volts.
NICE! Are you spraying through your shifts? Yea, I wouldn't go ***** out until your FP is ironed out. You are not using a dedicated fuel system for the nitrous correct?
I also agree with what the guys said about your shift points...That puppy is making power up top now with the 90/90.
Old Feb 11, 2009 | 05:00 PM
  #28
tarinitup's Avatar
9 Second Truck Club
Intank is on stock wiring and inline is in on it's own wiring. That time decrease was all motor I haven't made a full nitrous pass cause it cut off on the FPSS. When I get the chance I will be spraying through the shifts and yes I'm still running nitrous off fuel port.
Old Feb 11, 2009 | 05:04 PM
  #29
tarinitup's Avatar
9 Second Truck Club
stock suspension with 2" shacke drop and caltracs. Slick was spinning cause valve stem ended up on a different letter everytime. In hind sight I got the best hook with 15 psi and then started to go up as I decreased air. I'm going back this weekend to practice more on the launch cause I know it has alot more left in it.
Old Feb 11, 2009 | 05:08 PM
  #30
tarinitup's Avatar
9 Second Truck Club
Sounds promising!!
It was 8.27 @ 86 with 4947 DA. When I ran 8.7s @ 82 in the 1/8 at my home track it came out to 13.0's @ 104 in the quater at SAR.
