TIME SLIP DATABASE
Balls to the wall for SAR meet
Old Feb 2, 2009 | 07:06 AM
tarinitup's Avatar
9 Second Truck Club
Originally Posted by Flaco
in my opinion peeking 27 is a little to much ...i would lock it at 24 from 3500 to redline...remember not just because you run higher timing means it will perform better, it means the cylinder will get hotter..u running tr-6 correct.. i would gap them .030...also you running 4.10? i would lock converter as soon as it shifts to 3rd gear...let it go 5 mph after 3rd then lock... did u run the truck on dyno only with NOS..if so on a full load it differs when on the gas, especially on 3rd gear with 27*...just my .02
Good Luck
Flaco
I've never been on a dyno and the 27 was just my guess, 24 I do rememver vividly. Allen has always kept it safe and I completely trust him. How much timing do you add when using race gas vs 93 octane and are the gains worth it. I've never experimented with race gas.
Old Feb 2, 2009 | 07:10 AM
tarinitup's Avatar
9 Second Truck Club
Originally Posted by TxSqueeze
Manny, the new wheel/tire and stall alone would get you what your wanting! That thing is gonna be a beast now! As far as weight, you've taken everything out that I would have. Besides the front passenger seat! Also, get under the truck and take off all of the heat shields, and hitch if you have one. Don't worry man, your 10sec pass WILL happen at SAR. Good luck man.....
Austin
PM sent by the way.....
I was also thinking about removing the front seat but that's probably where I draw the line. I'll look for extra un-needed stuff under the truck though.
Old Feb 2, 2009 | 07:32 AM
tarinitup's Avatar
9 Second Truck Club
Almost forgot about a fueling issue that needs fixing. I recently installed a 255 walboro inline in addition to intank and now my fuel pressure is dropping from 60 psi idle to 58 psi wot. Before it would hold 60 psi NA and only drop with nitrous use, havent checked it on Nitrous yet. Since the intank is older I'm thinking it's not pushing as hard as the inline. Or am I just being too cautious and 2 psi drop is nothing to worry about?
Old Feb 2, 2009 | 12:23 PM
Flaco's Avatar
8 Second Club
race gas vs 93 , it all depends on each vehicle.but if your only using a couple of gallons it does not do much, but if your using nothing but race fuel then you can go more agressive on the tune.
on race fuel since the burn rate is faster you have to add a certain % of fuel across the board
Old Feb 2, 2009 | 01:46 PM
Wheatley's Avatar
Truck Sponsor
your pressure dropped after you installed the walboro?
Old Feb 2, 2009 | 03:41 PM
zippy's Avatar
On race fuel you should be able to run 27 degrees with around 24 at torque peak as long as you keep the AFR to around mid to high 11's. I would shift at 6700/6600 and lock the converter at around 110. You should be trapping well into the 120's.
Old Feb 2, 2009 | 06:55 PM
v8
17,16,15,14,13,12,11 Drvr
well after locking my converter several times it has just about taken a ****, its good for track times but overall it will eat your converter up, I have a 3disc PI allmost a 1disc now ahhhaaa
Old Feb 2, 2009 | 09:34 PM
tarinitup's Avatar
9 Second Truck Club
Originally Posted by Wheatley
your pressure sropped after you installed the walboro?
yeah and both pumps run at the same time.
Old Feb 3, 2009 | 12:32 AM
zippy's Avatar
Do you have a wideband gauge in the truck?
Old Feb 3, 2009 | 07:01 AM
tarinitup's Avatar
9 Second Truck Club
Wideband readings are normal 13.0 at wot NA. I'll check nitrous afr this weekend.
