TIME SLIP DATABASE
Baby Cam gets little better times
Old Nov 23, 2006 | 12:32 AM
TouchOfEvil04's Avatar
Default Baby Cam gets little better times
Well i went to the track again tonight.Everything is still the same.Still running out of injector at 5200rpms still lame tune in it for now.
Just 9degrees better weather.
I was spinning out the hole.Mainly from what i think is from the chevy lean causing the majority weight to go on one tire over the other.My rubber amount on my driver side is a ton while the passenger side is only a little.Gotta get the lean fixxed.
Truck is beggin for a 3200stall. The 2600 is just not in it's powerband at all.It soon shall come.
DHL2006"Derek" was gonna run on my ET's but the track got shut down on us cause a bike wrecked.We think the guy is ok but not sure 100%.
Anyway here's the slip and i'll post the video as soon as streetfire says it is ready!
Video: http://videos.streetfire.net/video/d...82001e14d0.htm
Old Nov 23, 2006 | 02:46 AM
Cuerva's Avatar
11 Second Truck Club
Congrats on the new numbers.
Old Nov 23, 2006 | 03:33 AM
Thanks man. I can't wait to get the next few planned mods complete!!!!!
Old Nov 23, 2006 | 08:54 AM
litreddevil's Avatar
Banned
great times so what is coming up next
Old Nov 23, 2006 | 03:00 PM
Fix my suspension so it doesn't pull 75%left tire 25%right tire.Get my stall restalled to a 3200 or just get a new one.
Having my heads sent off to WCCH soon for a stage II job on em.
Upgrade my injectors to 8.1marine 42lbers.Those should be on the way already.
Then make a trip to Texas and get this god awful tune fixxed up so it runs like a champ.
12's n/a here i come!!!!!
Old Nov 23, 2006 | 04:03 PM
Derek @ EDO's Avatar
FormerVendor
yep all that where he can hang with me, still behind me but with me lol JFWY
Old Nov 23, 2006 | 04:28 PM
Mangled03gmc's Avatar
Baltimore Whore
So all ya gots is tha lq4, cam, tune and that 2600 stall.. Thats a sweet time, man can't wait to see it get faster.. good luck
Old Nov 23, 2006 | 04:36 PM
Well i'd say lq4 cam and 2600 stall.The tune isn't much of a tune right now.
The only things that are changed from a stock lq4 tune is the air/fuel which only helps til 5200rpms cause i max the injectors out above that.AT 100%at5200rpms.
And the idle was bumped up to 825 to stop the surge of the cam.
Everything else on the tune is 100%stock.So i have ALOT left in the tune as of right now.
Old Nov 23, 2006 | 04:38 PM
Ya motha.
We shall see how your truck does with the one wheel and and the Et Streets lol.
Maybe you will hit a 13 then.
Old Nov 23, 2006 | 08:20 PM
ap2002's Avatar
congrats on the new times.... do you run on e/t's??
I'll like to see what it does with the 42lbs injectors and a real good tune and with the same converter?? I bet you could dip into the high 12's.... you are almost close on the mph, with a good tune the mph should go up for sure...
by the way who does your tuning in texas??
