TIME SLIP DATABASE
anybody hauling ass NA with 5.7 aluminium motors?
Old 01-04-2013, 11:51 PM
  #21
slowlsx's Avatar
As soon as the track opens up in 3 weeks. Should have it startedup tomorrow!
Old 01-05-2013, 01:44 PM
  #22
slowlsx's Avatar
So what do you guys think about running a nice stainless merge pipe to create bettrr exhaust flow or go witg 3" duals? Im pretty set on tsp 1 7/8 long tubes
Old 01-05-2013, 06:42 PM
  #23
skeet's Avatar
Originally Posted by DTHPROOF
Sounds like that motor in your signature is the ****! lol Anyone running these times with a TBSS intake? I don't want a FAST with the issues people are having and my motor's biggest downfall is the stock intake on it. I think mine with a TBSS intake, NW90mm TB, and the 4.30's will pick up quite a bit. You guys with these 11-second trucks are pumping me up! I thought I'd need at least a 100 shot to run those times.
i used to run the nbs rectangular port intake, it was great, with a 90mm tb, gears are part of the puzzle in gaining and producing the times i hit, i built my LQ9 to be all out NA motor, so i went with a 4:88 gear
Originally Posted by slowlsx
Word. Im thinking 430 or 456 gears should match the converter nicely.
I should have it running this week and just waiting for the track to open back up!
its not so much matching the converter, its what you want your setup to do, you want a all out motor then go 4:56, i ran a 4:88 gear 28" tire the bitch launched hard
gears dont match converter, converter matches peak torque at a certain rpm
my opinion 3" dual nothing less !
Old 01-05-2013, 07:22 PM
  #24
slowlsx's Avatar
skeet do you have any results from doing gear swaps? i would be really interested to see what 456 would do over 410's
Old 01-05-2013, 08:09 PM
  #25
skeet's Avatar
no but if i had to guess at least 2 or 3 tenths maybe more, specially from a 4:10
thing you wanna do is find out where your peak torque is, once you know that then you wanna choose the stall speed, if i had to guess youre real close with a 4500, if you can foot brake that thing at around 3500-4000 youre golden, but hoping you dont push through the brakes, if i had to guess your peak torque is probably around 4400 which the stall is gonna be bad *** when it flashes youll be right at peak torque, shift it at 6200-6400 i personally think i was over shifting my lq9
i was shifting my 408 at 6900 then after looking at the paper work and calculating a few things we esitmated peak torque around 4800-5k, i run a 4600 stall now, i dropped my shift points down to 6200 i was like hmmm, so i upped them alittle after each pass, the gains it showed were pretty decent, so from 6200-7200 the sweet spot was actually 6600
then i started messing with the timing, i pushed a buttload until she wouldnt gain anymore making necessary adjustments , she finally settled at a nice 34* ( im not saying do this ) im saying i read my plugs NA and also on nitrous i tuned by them. or should i say made adjustments. i have pushed 36-38-40 * didnt gain anything pass 38 so i backed off 4*
Old 01-05-2013, 08:30 PM
  #26
slowlsx's Avatar
Those woukd be killer gains over 410's, you see i figured my peak torque woukd be well over 4000 abd Chris at circle d tokd me 5c (4400-4500) would be about as high as he could go so i figured it woukd be pretty close! I think 456 gears will be about as high as i want to go since i still want to drive it on the street.
Now i just need to find a cold air intake or build one -_-
Old 01-05-2013, 08:51 PM
  #27
skeet's Avatar
thats the same converter i used to run , his 5C 4500, i hope you have a triple disc
im surprised he didnt build one like the one i have, supposely special lol i sure know it works well, just alittle tight than what i wanted but i yet to really break it in 4:56 will suit you fine, lol i used to drive to houston ( baytown ) with 4:88s 3k rpms a detune wasnt bad i have 4:56s now, and yeah i miss my 4:88s
Old 01-05-2013, 09:11 PM
  #28
slowlsx's Avatar
Well ive had the converter for a while so i just went ahead and did what i could witg it.
Did you do anything fancy with your cold air system?
Old 01-05-2013, 09:38 PM
  #29
skeet's Avatar
its made out of turbo piping, twin tube, comes out of each head light
Old 01-05-2013, 09:48 PM
  #30
silverz28camaro's Avatar
I went 13.42 @96 mph with a Internally stock 1998 LS1 ...mods were headers, CAI, ls6 intake manifold, Kimbler 60E and a yank sstb3600(similar to ss3600, just a hair tighter) also 3.90 gears with 30 in street tires
Quick Reply: anybody hauling ass NA with 5.7 aluminium motors?
