Any guesses on my ET's when I get it completed?
New to drag racing and curious as to projected times. My track is mainly 1/8 mile. I've had Martin at Tick and my local LS guru give me an estimate of 500HP on motor but I want opinions. Truck is as follows:
2000 Chevy RCSB 2wd Stock LQ9 235/242 .620/.593 109+2 w/ pushrods and springs Vic Jr with Mighty Demon 850 annular 150 shot to start with 1-7/8 longtubes thru 3" and bullets TH400 w/ rev man valve body, transbrake, and roughly 3600-4000 stall Most likely 14 bolt with 4:10 and spool 28" slicks at least I'm going to lighten truck as much as possible during construction with hopes of being in the 3500-3600 range. Any rough ideas of 1/8 and 1/4 times and speeds? Thanks! |
7.40s to 7.50s in the 8th and mid 11s in the quarter
You need more gear...
As in 4.56 or 4.88??
To give you base I has 100 shot, 2800 stall, tune, and a 4l80e ran 13.4. Only had one track time with that set up so might have been a bit faster at 13.2or so.
You have the cam, bigger stall, lighter trans, gears, 50 more of nitrous, exhaust, and maybe one or two more. The nitrous brings you to 13 flat off my time, and I am guessing everything else should be good for 1.5-2 seconds. Low to mid 11s are realistic. I would set my goal at 11.99 and anything better is great. If you want to be aggressive with your goal 11.75 seems very reasonable, but I like to set goal high and be happy to smash it. Rather than set it where it "should" run and get let down. |
I really wish youd stop comparing your numbers from almost half a decade ago to someone who's actually trying to build a truck for the track. And once again, you were running a long bed 3/4 ton with a stock 6L and he's talking about a 1/2 short bed truck that's going to be properly setup and lightened up a good bit, never mind the fact he said nothing about making full 1/4mi passes and that's all you have to base anything off of... Apples to oranges... Tell us again how many passes you have made in that truck??
For strictly 1/8mi, I'd do more gear and converter both. You've got the cam, intake and exhaust system to let her breathe up top. Did I miss what heads you plan on running?? |
With some good heads, I will guess some 7.3 et's @ 95mph.
1/4 prob near 11.3-11.4 et @ 118 mph |
Originally Posted by pittman
(Post 5187294)
Will a set of Caltracs suffice for this setup?
It should if they're set up right. I'd look into assassin bars by Smith Racecraft if you plan on keeping leaf springs too.
