TIME SLIP DATABASE
4.8 goes 12.17
Old Aug 12, 2009 | 07:09 PM
  #101
Derek @ EDO's Avatar
FormerVendor
Originally Posted by 00ChevyScott
Thats epic!
Old Aug 12, 2009 | 07:13 PM
  #102
kylloso's Avatar
im runing on 28 hoosiers slicks ..... and well lets see wut happens this saturday at the shootout down here....
Old Aug 12, 2009 | 08:04 PM
  #103
gtosilverado's Avatar
Old Aug 17, 2009 | 06:53 PM
  #104
McAllenSS's Avatar
Congratulations Kyle.. Once you slap on your stall and headers, Expect high 11's homie!
Old Sep 6, 2009 | 12:53 AM
  #105
ZTwentyAteU's Avatar
If you ran the times that you stated, rock on.
But it IS hard to believe. I just sold my little z28 last week, it ran best of 11.01 @ 123 at beech bend with a small cam/ boltons/ stall/ and 150 hit. It ran 6.90s-7.0s in the 1/8th. If you ran 7.80s, you must have sprayed a huge 2nd stage down track
Old Sep 7, 2009 | 09:33 PM
  #106
slowlsx's Avatar
Being in the 1.7 60's on a stock stall 4.8 runing 12.1..... If he puts a converter he should be in the 1.5's easily right?
Old Sep 27, 2009 | 10:15 AM
  #107
IH8FORD's Avatar
10 Second Club
Great times I would like some more info on the truck. Like what size rimes and tires are you running and what year is the truck so I have a better Idea on weight of the truck.
Old Oct 1, 2009 | 01:17 PM
  #108
as of last night he has a new best of 11.9... congrats to kyle!!! not sure if he made any changes to his set-up, hopefully he'll chime in
Old Oct 19, 2009 | 01:13 PM
  #109
dug's Avatar
dug
Banned
'da has a huge impact on times. I raced my old camaro on a hot summer day and the results were embarrassing. Then when I raced it on a cold day it ran like it should.
Also, stock stalls work great with nitrous if the motor doesnt blow up from the juice being hit so low. Its not recommended to spray below 3k. But the motor is probably ok cuz its the same as the 5.7L and the cylinder pressure isnt that high from the small displacement and big cam. So the heads wont lift. Also a good nitrous cam will help the restrictions from stock exhaust manifolds.
It probably dynos around 275rwhp without the spray and 400rwhp with the spray. Then at the mine shaft track its probably making around 430rwhp. Also, arent the stepsides the lightest truck? It obviously has some weight reduction without the tailgate.
I dont think the results are that controversial. Its a pure nitrous setup thats a slug without the jug.
AdaMax
May 16, 2016 11:35 PM
legerwn
56
Nov 15, 2015 10:21 PM
97_ek
Sep 23, 2015 09:16 PM
vipergtrdj
Sep 11, 2015 05:52 PM
hackrst
Sep 2, 2015 05:27 PM
