Just got back from the Richmond Dragway..
Old Jul 1, 2005 | 11:55 PM
Jrgnd's Avatar
Default Just got back from the Richmond Dragway..
Did 16 passes. Tailgate off. Besides that full street trim(5280 lbs).
Worst pass: 15.2008 at 88.97(95.5F, 34.5 % Humidity, 29.71 Hg, Altitude 200 FT and Density Altitude of 3038 feet). No manual shifting.
Dial: .00
Reaction: .7106
60 FT: 2.2092
330 FT: 6.3449
1/8 ET: 9.7749
1/8 MPH: 72.86
1/4 ET: 15.2008
1/4 MPH: 88.97
Best pass 14.87 at 91.48(81 F, 62% Humidity, 29.75 Hg, Altitude 200 FT and Density Altitude of 2138 FT). Manual shifting at 6100 RPM.
Dial: .00
Reaction: .5105
60 FT: 2.1815
330 FT: 6.2211
1/8 ET: 9.5770
1/8 MPH: 74.16
1/4 ET: 14.8744
1/4 MPH: 91.48
With better weather I could have gotten a best of 14.44. I am hooked.
Old Jul 2, 2005 | 10:18 PM
pretty good for quad cab and hot weather
Old Jul 2, 2005 | 11:39 PM
Jrgnd's Avatar
Thanks. I am trying to convince myself and get a underdrive pulley. But a programer which keeps my horsepower but firms shifts, adjust shift points and gets rid of some torque management would put me in the low 14s high 13s with my current setup (With better traction).
After the pulley and a better programer, it's cam time baby. I should just bite the bullet and buy a 426 Hemi. But that would be too easy and expensive.
Old Jul 4, 2005 | 12:09 PM
Rumble Bee Ram's Avatar
Nah, you'll never hit 13s with your mods and just adding another programmer to it, you are already running a HYPERTECH and the new superchips in no fit, form, or fashion is going to shave another second off your already modded and programmed truck. You might pull a 14.4 to 14.6 at best when you add the superchips programmer. It takes alot to dump a half second to a full second off of our trucks, especially with you having the weight of a quad cab. You need to look into some weight reduction mods, you already have some good mods to pull it thru the 1/4, but the overall weight is killing you, also what is the weight and size of the tire/wheel pkg. you have vs. the factory ones. If you went lighter, you'd really be surprised as the difference it makes in times.
Old Jul 4, 2005 | 10:22 PM
Jrgnd's Avatar
I have lighter rims than stock. 4 pounds lighter. Will see what time I get with better weather.
Old Jul 7, 2005 | 11:31 AM
Five9Dak's Avatar
Nice times for a full size QC truck, creapping up on my regular cab midsize times lol.
(holy ****! 16 passes, does anyone go to that track? or was it just you?)
Old Jul 7, 2005 | 03:22 PM
Jrgnd's Avatar
Not if the weather is bad. I am going on the 15th, by then I am hoping to have a ASP Underdrive Pulley, 180 Degree Thermo, Taylor wires and NGK 5306 plugs. We will see what happens....
FlowmasterMufflers
Oct 26, 2015 06:19 PM
FlowmasterMufflers
Aug 14, 2015 01:04 PM
FlowmasterMufflers
Aug 14, 2015 12:47 PM
05GMC4.8
Aug 7, 2015 09:55 PM
FlowmasterMufflers
Jul 22, 2015 01:29 PM
