Dodge Engine & Exhaust Performance All EFI, Hemi, Magnum, 4.7, 5.9
problems with ram
Old Mar 26, 2010 | 06:34 PM
jwh132394's Avatar
Default problems with ram
this morning my dodge started hesitating when taking off from a stop, it is bucking between 20 and 30 mph and my tach jumps all over the place. i cleaned my throttle body and air intake and my trans fluid is good. it is a 2005 dodge ram 1500 with the 5.7L engine any help would be appreciated.
Old Mar 26, 2010 | 07:32 PM
2005 Silverado's Avatar
SPAM HUNTER
If the tach is jumping around you might check a crank sensor, Im pretty sure they use a cam and crank so even if you loose one it will run, but if it dies, it wont start.
Just an idea.
Old Mar 26, 2010 | 07:42 PM
FrostKing's Avatar
Any codes?
Old Mar 27, 2010 | 04:42 AM
jwh132394's Avatar
the only code is for the egr and its a stored code not a current code and my egr valve is fine
dsbodley
Nov 14, 2015 09:46 PM
thewrx
Oct 6, 2015 10:59 AM
02AWDAWSDenali
Oct 1, 2015 05:08 PM
Slammed silverado
Sep 28, 2015 06:14 PM
