Dodge Engine & Exhaust Performance All EFI, Hemi, Magnum, 4.7, 5.9
Have a 2012 Dodge 1500 4x4? Want a free suspension & shocks?
Old Nov 14, 2011 | 01:46 PM
Rancho Suspension's Avatar
FormerVendor
Talking Have a 2012 Dodge 1500 4x4? Want a free suspension & shocks?
We are looking for a 2012 Dodge 4x4 1500, we need to check out the suspension since Dodge made a transmission switch. We would need it for a couple of days.
Click the link and an engineer will be in touch.
Thanks
Rancho Suspension: Vehicles Needed
Old Nov 14, 2011 | 02:20 PM
badblackhemi's Avatar
Posted this on another big dodge website for you.
Old Nov 14, 2011 | 02:28 PM
FormerVendor
Thank you!
Old Nov 14, 2011 | 02:37 PM
No problem! It's a great deal for someone. I posted it on dodgetalk in the 4x4 section for the 4th gen trucks. Best place for it to get some views.
Old Nov 14, 2011 | 04:10 PM
1994Vmax's Avatar
On the half tons the transmission isn't actually changing. Its still the 545RFE with programming changes letting it shift 2nd and 2nd prime all the time if you want it too. They simply rebadged it as the "65RFE". See below,
The Ram truck brand is increasing the number of gears available for its 2012 light- and heavy-duty pickups with the introduction of two six-speed transmissions.
Light-Duty Ram Transmission Changes
The 2012 Ram 1500 half-ton sees the previously offered 545RFE five-speed automatic gearbox recalibrated and upgraded to take full advantage of the split 2nd gear, so all six speeds are available to the driver in a newly available "Electronic Range Select" mode.
The 545RFE transmission was unique. Even though it was identified as a five-speed transmission, 2nd gear was split into two cogs, depending on whether you were upshifting or downshifting. On the way up, it was 1.67, but there was a 1.50 "kickdown" ratio on the 3-2 downshift to smooth out what would otherwise be a large gap between the gears. Fourth and 5th gears were overdrives for improved highway performance and fuel economy.
Electronic Range Select mode lets the driver manually limit the highest available transmission gear, allowing manual upshifts and downshifts based on road speed and engine speed. It's especially useful for towing through hill country when the climbs and descents are closely spaced together.
The recalibrated 545RFE in the Ram 1500 is now called the 65RFE automatic six-speed.
In full auto-shift mode, the 65RFE behaves the same as the old 545RFE, keeping the split 2nd gear and kickdown behavior. Also added is a new torque converter that's expected to marginally improve fuel economy, but not enough to boost EPA mileage ratings.
The 65RFE is standard with the 4.7-liter V-8 and 5.7-liter Hemi V-8 gas engines.
Heavy-Duty Ram Transmission Changes
The 2012 Ram 2500 Heavy Duty pickup also gets a new six-speed automatic transmission, called the 66RFE. It replaces the previous Hemi V-8 gasser's 545RFE gearbox, which was shared with the light-duty Ram.
The 66RFE transmission is a hybrid of sorts. It combines the internals of the 68RFE heavy-duty six-speed automatic (including the gear ratios) that's paired with the 6.7-liter Cummins six-cylinder diesel engine and repackages them in the 545RFE's case.
Like the 65RFE, the 66RFE offers Electronic Range Select to lock out gears on demand.
The 66RFE is standard with the 5.7-liter Hemi V-8 on all Ram 2500 models..
Old Nov 14, 2011 | 04:14 PM
FormerVendor
Talking
Good to know. An engineer actually let me know it had more to do with a front axle mounting issue, I can't remember which side now.
Do you have anymore info on the front axle?
Thanks!
Old Nov 14, 2011 | 04:45 PM
1994Vmax's Avatar
Thanks!
That I am not sure on. I just dug in on the the transmission as a previous Ram owner to find out what the new transmission was. Honestly was disappointed it's still the same old 545RFE. It's odd because it still shifts just the 5 gears as it always has when left in Drive, so really it's just the range selection thing that has been reprogrammed. I could make my old 09 manually upshift using 2nd and 2nd prime if I wanted too.
I am sure maybe one of the Dodge forums has some info from Chrysler on if the front suspension changed at all. It is a great deal for someone though from you guys!
Old Nov 24, 2011 | 10:59 AM
LightFighter's Avatar
still looking for a Truck I just got a crewcab
Old Nov 28, 2011 | 10:36 AM
FormerVendor
I believe so, click the link above. Are you still in Jersey?
Old Nov 29, 2011 | 06:53 AM
yes I'm still in NJ
