Dodge Engine & Exhaust Performance All EFI, Hemi, Magnum, 4.7, 5.9
comp cams in a hemi
Old Jul 23, 2012 | 04:07 PM
landon1405's Avatar
Default comp cams in a hemi
hey guys we just did a cam swap in a 11 model ram with a 5.7 and the tech said it runs fine but when you go to stand on it he says there is no throttle response and no power down low but starts pulling hard up top. the tech tells me a stock hemi would blow the doors off this cammed hemi. any ideas of what might be the issue.
Old Jul 23, 2012 | 06:01 PM
Burgundy&TanMan's Avatar
has it been tuned? far as I knew B&G were the only ones who could reflash a '10 pcm for this kind of mod. If theyre saying any other tuner besides them did the tune I think there fibbing! But its in the tune for sure I installed a cam in the silverado in my sig and before i tuned it it really wasnt any faster
Old Jul 23, 2012 | 08:43 PM
DR132's Avatar
what cam did you put in? if you change nothing else putting a big cam will kill your low end and you need to make other modifications to make up for that, most commonly lower gears and/or a higher stall torque converter. tuning is also critical for it to run right...
Old Jul 24, 2012 | 03:38 PM
62nalide's Avatar
cant he just use a 2010 PCM and tune it and be done with? or not that easy?
Old Jul 24, 2012 | 04:37 PM
landon1405's Avatar
i dont have the cam card anymore i just remember it was like 615 lift and 111 lsa but the pcm was sent to bgchrysler for the tune.
Old Jul 24, 2012 | 04:45 PM
landon1405's Avatar
truck had full header back exhaust, cai, bbk tb.
Old Jul 28, 2012 | 11:22 PM
DR132's Avatar
well, a cam like that probably has a pretty long duration and will kill the low end and pull hard up top. he needs higher stall converter to keep in the power. lower gears will help too. then it will rip.
low2001gmc
Jul 23, 2015 05:10 PM
Ammadien
Jul 22, 2015 08:50 PM
WICK3DxGATA
Jul 21, 2015 06:59 PM
projectnightcrawler
Jul 19, 2015 11:30 PM
4B11T
Jul 13, 2015 03:48 PM
