cummins problem
I'd check your fuel pressure from the lift pump. With the 02 the failure of the lift pump can kill the injector pump, which will lead to a hefty repair bill. The white smoke could be a faulty injector. I'd take it to a reputable diesel shop/dealer and get it checked out. The couple of hundred $$ it cost's you may save you a couple thousand $$ in repairs if you keep driving it the way it is.
How long has it been since you changed the fuel filter?
Just a thought.
Randy
Just a thought.
Randy
yep you got dead pedal syndrome...your lift pump took a ******* on you and is killing your injection pump...very very common on 98.5-02 cummins with the vp44...its almost a must to have a fuel pressure gauge on these trucks...changing your fuel filter might help but most likely the damage is done...
2002_Z28_Six_Speed
Oct 4, 2015 01:34 PM
