cummins problem
Old May 27, 2008 | 05:01 PM
BANSHEEATER's Avatar
Default cummins problem
i have an 02 cummins and sometimes ill be crusing along and it wont accelerate ill push the pedal to the floor and after about 8 seconds it will take off anyone else have this problem
Old May 27, 2008 | 05:09 PM
2005 Silverado's Avatar
SPAM HUNTER
Have you checked your Throttle pedal assembly. If its bad it will cause a stumble or no throttle response
Dustin
Old May 27, 2008 | 05:12 PM
the pedal seems fine and it accelerates fine most of the time
Old May 27, 2008 | 05:21 PM
SPAM HUNTER
Check your connections for any debris, they can be very sensitive.
Dustin
Old May 27, 2008 | 07:50 PM
the_husk's Avatar
At idle or moderate throttle, is there blue or white smoke coming out the exhaust? I hope someone else chimes in on this, but couldn't it be an injector going out or something?
Old May 28, 2008 | 04:06 PM
when its cold there is blue/white smoke
Old May 28, 2008 | 04:16 PM
NoChrome's Avatar
how do you drive it? like an old man, or like a kid?
Old May 28, 2008 | 04:19 PM
SPAM HUNTER
Blue is oil, White is lack of fuel or water
Dustin
Old May 28, 2008 | 11:52 PM
if i let off the pedal and then push it again it goes back to normal
Old May 29, 2008 | 12:23 AM
SPAM HUNTER
The smoke goes away, or it quits stalling?
I would say check your lift pump, it could be going out and not supplying the full and optimal amount of fuel, but its hard to say not being there.
Dustin
