coolant leak
Old Apr 8, 2014 | 11:47 AM
k9735mm22's Avatar
Registered User
Default coolant leak
if any one has experienced this ,i would appericate input, i have 1994 Chevy k1500 350 sm blk ,have coolant leak behind engine near the distributor ,no water in oil , so i dont believe its head gasket
Old May 20, 2014 | 09:08 PM
aldrichg9's Avatar
I had the issue on my 90 with the aluminum fitting at the back of the intake manifold passenger side.
Is that we're yours is coming from?
I just drilled mine out and tapped some threads into it so I could screw in a nipple and no longer used the fancy gm hoses.
Old May 20, 2014 | 09:20 PM
rossp's Avatar
Sounds like an intake gasket to me. A pressure test with a mirror would probably pin point it fairly quick.
Old May 20, 2014 | 09:58 PM
Jblake's Avatar
I know the vortecs are common for it. Mine was leaking the same spot. But not too familiar with the. Tbi motors. But I wouldn't rule out the intake gasket
Old May 20, 2014 | 10:16 PM
lady3bglover's Avatar
There are more than a few threads on this condition... P0300
https://www.performancetrucks.net/fo...-p0300-529309/
There's a search engine at the top of this page....
Old May 21, 2014 | 09:22 AM
aldrichg9's Avatar
lady3bglover:
While I'm sure you are correct that there are other threads on this common issue with the early throttle body engines....
I don't see what P0300 and the thread you linked to about misfire condition has to do with an intake coolant leak.
bearden86
26
Nov 15, 2015 03:58 PM
03sierraslt
14
Oct 9, 2015 05:53 AM
02AWDAWSDenali
Oct 1, 2015 05:08 PM
sTNT971
Sep 26, 2015 04:22 PM
