92 c1500 problem
Old Apr 1, 2012 | 06:08 PM
ryan_wagnon's Avatar
Was not fuel pump. i now rebuilt throttle body and fuel pressure regulator and still didn't fix it. Its driving me crazy lol
Old Apr 1, 2012 | 07:12 PM
which sensors could go out and not throw a check engine light?
Old Apr 2, 2012 | 07:18 AM
Hivelocit's Avatar
When you rebuilt the TBI did you use carb cleaner in all the vacuum ports? Mine had a lot of build up and was restricted. Check your Throttle Positioning Sensor also, as well as your EGR Valve! I originally had your same problem, replaced almost every sensor, intake manifold, rebuilt the TBI, replaced fuel pump and fuel filter, checked engine compression which was not too bad truck had 150,000 and when all of that failed started over back to the EGR and after careful examination and cross referencing parts realized the after market EGR I bought was the wrong one! Not my fault the guy sold me the wrong part, it happens though..
Old Apr 4, 2012 | 05:08 PM
BrutalSierra's Avatar
Originally Posted by gmstrong
replace those plugs and wires.then go from there.
BTW the 1 module with the line going to the TB is the egr solenoid,i forgot the other part with the large harness.Who the f*** mounted the map sensor like that?check the vacuum from the map sensor to the back of the TB also.Why is everything rigged you have a spring on the thorttle bracket for what?
I've got a 95 and my map sensor is in the same spot.
OP; check your catalytic converter. It might be clogged. Try hittting it a few times. If you hear things rattling inside it's bad.
Old Apr 4, 2012 | 08:46 PM
retorq's Avatar
Isn't that in the back by the distributor??
Old Apr 5, 2012 | 05:41 AM
gmstrong's Avatar
GM mounted the MAP sensor on the ESC mounting block.I had a 90 tbi350 and was mounted next to the esc.All of the tbi's ive seen where the same.
Old Apr 5, 2012 | 06:08 PM
figured out it only does it with less than a quarter of a tank. Guess ill keep a full tank
Old Apr 5, 2012 | 11:49 PM
retorq's Avatar
Temp sensor I believe... it will read -40 and you'll run rich, no light if I recall right.
Old Apr 29, 2012 | 08:26 PM
06murder's Avatar
Check the egr valve .mine did it got tired of it all was stalling and driving like ****...so try it.take it out and blow on the tip see if the valve in side move if its a no go the replace
madmann26
Apr 29, 2020 09:17 AM
dsbodley
Nov 14, 2015 09:46 PM
2002_Z28_Six_Speed
Oct 4, 2015 01:34 PM
02AWDAWSDenali
Oct 1, 2015 05:08 PM
sTNT971
Sep 26, 2015 06:27 AM
