84 C/10 5.3L swap... ANNOYING QUESTION....
Old May 3, 2012 | 03:16 PM
nonnieselman's Avatar
Ive done about 4 harness and working on one more. its pretty easy, just time consuming to get it just the way you want it.
Old May 3, 2012 | 03:18 PM
check this one out.. i said 77 but its actually a 80... woops..
https://www.performancetrucks.net/fo...80-4x4-493118/
Old May 3, 2012 | 09:13 PM
juveteach's Avatar
I just picked up a FLEX FUEL intake tonight, there getting kinda tough to find. I've been looking awhile. Everything is coming together....
FYI...In case you didn't know the FF intakes use larger injectors. I think they're 33lb or 36lb vs the 26lb regular 5.3 stuff. = more fuel pressure + more flow...
Old May 3, 2012 | 09:19 PM
juveteach's Avatar
Anyone know the GM part number for the vette style filter and reg combo, right off the top of your head???
Thanks....
Old May 3, 2012 | 10:29 PM
juveteach's Avatar
Never mind guys, I found one at O'reilly AP for 20.00. Looked for a 2k vette fuel filter and there it was. Cheap enough. Now to find the fittings.
Old May 3, 2012 | 11:09 PM
gavin2005's Avatar
im putting a 5.3/60e in a 87 c10 now.i'm using dirty dingo's adjustable motor mounts.brp racing mid length headers.stock driveshaft is gone work and shifter linkage.oil pan clears fine
Old May 4, 2012 | 03:09 PM
85SILVER's Avatar
Default c10 swap
Google (Glock's new project,"Fred) and you will get a lot of information there.
Old May 9, 2012 | 09:57 AM
juveteach's Avatar
Just ordered 5.3 today. PSI beehive valve springs are on the way. Cam is going to cam grinder by the end of the week. Having a RE-GRIND of GM's ASA LS1 cam...should be pretty nasty sounding, can't beat 75 bucks vs 400...
I will take pics soon and post....
Old May 18, 2012 | 01:06 PM
kainedogg's Avatar
Subscribed. I am doing a similar swap in an '84 C10. Just wondering if its more cost effective to get a 4l60e instead of reusing the stock th350.
Old May 18, 2012 | 01:11 PM
bowtieguy79's Avatar
Word of Caution. Those Orielly's house brand filters are cheap to buy and cheaply made. Don't use anything but WIX. ( WIX also supplies AC delco on this part )
I have had two of Orielly's house brand filters go into bypass on me and lean my engine WAY out, a little tough to diagnose. Spend the money and get a WIX!
