84 C/10 5.3L swap... ANNOYING QUESTION....
Old May 3, 2012 | 09:23 AM
juveteach's Avatar
Default 84 C/10 5.3L swap... ANNOYING QUESTION....
Hey guys, haven't been on here in a while. I am swapping a 5.3l into my old truck. I know its been asked a 1000 times. But I will ask it once more.
Is there anything "hinky" I should know about? Anything special I should be on the look out for?
I already have the engine, making the harness now. I have my choice of either a 6.0L or the 5.3L intakes, Not sure their is ANY advantages going with the 6.0L or not?
Got lsx swap engine mounts. Headers.
Is there ANYTHING I might be overlooking? I've been told the oil pan might not work.
Any comments from a veteran swapper, maybe shine some light on the subject?
Thanks in advance for any info...
Here's a couple pics of the old truck...
Attached Thumbnails 84 C/10 5.3L swap... ANNOYING QUESTION....-84-c-10-pictures-001.jpg   84 C/10 5.3L swap... ANNOYING QUESTION....-84-c-10-pictures-002.jpg   84 C/10 5.3L swap... ANNOYING QUESTION....-84-c-10-pictures-003.jpg   84 C/10 5.3L swap... ANNOYING QUESTION....-84-c-10-pictures-010.jpg
Old May 3, 2012 | 09:31 AM
smokeshow's Avatar
Mod with training wheels
I'll say this, if you think you have all your ducks in a row for a swap like this, don't be surprised when you don't. Something always hinders progress or bites you in the ***. I don't know how many times I brainstormed a project only to come across something completely unexpected. Just how it goes.
Old May 3, 2012 | 09:55 AM
nonnieselman's Avatar
we used the stock oil pan with no problems in a 77 and a 85
along with Fbody 1 3/4" LT headers.
Intakes are the same so use which ever you want.
just dive in and have fun..
what fuel pump / regulator / filter are you goin to use?
We used a walbro 255 inline, and a vette filter/regulator setup since it was cheap and easy to get.
Old May 3, 2012 | 11:45 AM
juveteach's Avatar
Thanks guys....
I have modified the stock fuel tank for an in tank pump set up. I am using a 255 style pump I got from O'reilly AP....I am also using the corvette filter and regulator set up. If the in tank pump doesn't work I plan on using a AEROMOTIVE 1000 pump I have. I think it should feed it pretty good. The only mods right now is a re-ground stock cam to the XR281HR COMP CAM ....should type that number in youtube and listen to that 69 or 70 model c10 cut up with it.
Well that's what I need to know, also the website that shows how to make you own harness isn't called LT1SWAP or something like that??? Anyone know of a better site for making your own harnesses???
Thanks....
Old May 3, 2012 | 11:53 AM
what year harness you using?
Old May 3, 2012 | 12:44 PM
juveteach's Avatar
One from a 02 2wd Tahoe...
Old May 3, 2012 | 12:49 PM
So is it cable or electric throttlebody? I cant rem if all the tahoes came with electric or not.
Its actually pretty dang easy.
All the pink wires get Ign Fused power, Orange gets 12V+ from battery, black goes to ground.
Old May 3, 2012 | 12:57 PM
juveteach's Avatar
It is cable operated. 03+ were electronic TB....ie drive by wire..
Old May 3, 2012 | 01:04 PM
oh ok you got it easy then..
I did my buddys 77 with a 98 or 99 Transam harness. we eneded up with 7 fuses and a fuseblock for pcm power and power for the relays.
lemme know if you need any help, its not hard at all to do.
Old May 3, 2012 | 01:39 PM
juveteach's Avatar
Cool....thanks. I will be using a 4L60e transmission. I will probably have about that many fuses and relays too. I going to try and use all the accessories I can. Good to know that help is only a few keystrokes away....Thanks...
