79 C10 5.3l swap setting up for auto x
#32
I just flipped the axle to be on top of the springs. Lowered the rear quite a bit. I am going to use the sway bar plates i got from the junk yard as my spring plates and run a bar in the rear. It is a 1 1/18" bar. I also got a 1 1/4" bar from the junk yard as well and am excited to run this setup.
I destroyed my transmission after i swapped in a z06 cam. So that needs to get swapped soon. Will get pictures up soon
#34
new spring perches to make the flip kit
axle on top of spring
starting the decent down
damn thing looks good!! need to do the disc swap so i can bring the tires into the fenders a little bit then i can roll the fenders.
#36
After destroying my 10 bolt i figured i would go overkill with this rear.
#37
So i dropped the truck down on its own weight and the tires were resting on the fenders. Not going to work. So i am going to flip my shackle like the 4wd guys do and allow me to bring it up a little and have better adjustability. Kind of a mistake but it will work out better in the long run.
#38
#40
My disc conversion brackets came in today....yay! Time to take the drums to the recycle yard to recoup some funds.
