71 Chevy Lsx swap 6.0
Old Feb 13, 2014 | 07:10 PM
  #21
Andy4639's Avatar
Talking Better pictures
Here are some of it sitting at Hawks after the dyno tune.
Fixing the park brake cable. It snapped.
Old Feb 14, 2014 | 12:28 PM
  #22
Andy4639's Avatar
Default Prep
Did some prep work this morning waiting on my rotors to get done. I cleaned up the drivers side spindle and painted the calipor, power steering sector and master cyclinder. Also greased up the front end and packed new bearings for rotors.
Attached Thumbnails 71 Chevy Lsx swap 6.0-dscf0602.jpg   71 Chevy Lsx swap 6.0-dscf0603.jpg   71 Chevy Lsx swap 6.0-dscf0604.jpg
Old Feb 17, 2014 | 05:35 AM
  #23
Andy4639's Avatar
Talking Rotors
Rotors installed.
Old Feb 18, 2014 | 12:45 PM
  #24
goinbrokez28's Avatar
Brakes look damn good Andy! Do you plan on upgrading to rear discs in the future? It's something I would like to do to my 85 one day.
Old Feb 18, 2014 | 12:55 PM
  #25
Few questions for you if you don't mind. Did you use the stock 80E dipstick, or run a Lokar flex style stick?
Is the truck column or floor shifted? I'm trying to figure out how to run the shift linkage for my column shifter without buying the Lokar unit for 4l80's lol.
Old Feb 18, 2014 | 04:24 PM
  #26
Andy4639's Avatar
Talking
I would like to but don't think I will ever get there. I may do the 13" drum upgrade though.
Stock dip stick no issues.
I have a S-10 floor mounted shifter with a B&M cable hooked to the trans. It's got lights and a lock out on it. If I need to I can keep the truck in park and it want come out of it.
Attached Thumbnails 71 Chevy Lsx swap 6.0-img_1051.jpg   71 Chevy Lsx swap 6.0-img_1055.jpg
Old Feb 22, 2014 | 06:27 PM
  #27
Blackpanther99's Avatar
sweet truck and build
Old Feb 22, 2014 | 08:29 PM
  #28
Andy4639's Avatar
Wink Thanks
Thanks,
It's a never ending story. When I get home tomorrow night I plan to tear the interior out of it to finish the deadner in the floor. I have the doors, back wall all done just need to take the seats out and finish it. While I have it out I may change to bucket seats out of my wifes wrecked Caddy with electric and heat.
Old Mar 7, 2014 | 08:09 AM
  #29
Andy4639's Avatar
Unhappy 4l80E
Took the truck over to the local transmission shop yesterday to check the leak on it. I didn't get the info I was hoping for. The wire connection is the part leaking not the pan gasket. Also said the rear bushing was bad. They had to order the connector so when they get it I have to take it over for them to do it.
Old Mar 16, 2014 | 04:06 PM
  #30
Andy4639's Avatar
Wink Drive shaft and transmission
I took the truck last Monday to have the new wiring installed and ended up having the truck took back to Hawks for the drive shaft work.
Long story short:
Hawks had the 2 peice cut to short to begin with. that in turn caused the rear bushing to go bad.
Hawks had a new 1 peice drive shaft built and installed in the truck. The fix. Replaced the tail shaft with new one I had bought from transmission place along with wiring connector.
Attached Thumbnails 71 Chevy Lsx swap 6.0-1-peice-drive-shaft4.jpg   71 Chevy Lsx swap 6.0-1-peice-drive-shaft3.jpg   71 Chevy Lsx swap 6.0-1-peice-drive-shaft.jpg   71 Chevy Lsx swap 6.0-1-peice-drive-shaft-2.jpg
