Central & Northern ND, SD, NE, KS, OK, MN, IL, MO, IA, KY, OH, IN, MI, WI
Help on a new project?
Old May 18, 2008 | 10:32 PM
truckmann's Avatar
Here are some other pics to give you an idea of the size of this thing. These are a little different, but it should help you get an idea of the dimensions. Basically if it is made to fit a keg on each stand, one above the next, then it will be about right.
Old May 18, 2008 | 10:40 PM
truckmann's Avatar
Originally Posted by dirt track racer 81
is there 1 winch or 2..what actually moves and how does it work..and can you get me some more pics
There is only one wench on the first one I posted. It is just to move the lower burner/pot stand. If you look close I think you can see that the lower platform is mounted on a sleeve instead of the main trunk that allows it to slide.
I sent a message to the guy who made it to try and get more info on it. Of course any modifications to make it better are welcome. I'm thinking maybe putting all of the platforms on sleeves so they can be adjusted and locked in place with set pins. There only needs to be a winch on the lower one though cause that is the only one that will need to be moved with weight on it.
Old May 18, 2008 | 10:44 PM
dirt track racer 81's Avatar
the bottom one is the only one that needs a winch? how far does it move up and down?
Old May 18, 2008 | 10:47 PM
truckmann's Avatar
you get all the measurements i need and possible if you can get me some 10 gallon pots that way i have them to when i build it i can..if you can get them ill meet ya at mcdonalds on cimarron turnpike
I probably won't be able to buy the bigger pots or empty kegs for a while due to cost, but I could meet to over there and give you one of the pots I am currently using. I might be able to borrow a keg-pot, I will have to check with some of my fellow homebrewers in the area. I have a couple of burners that can be used, at least until I decide to upgrade to some bigger ones.
Old May 18, 2008 | 10:57 PM
truckmann's Avatar
It would need to be able to raise the lower stand up to about a minimum of 25" above the ground or the base of the stand.
I just got a reply back from the guy who built it saying ask away on the questions! I'm going to see if he can send me some more detailed pictures, measurements on total height and distance between platforms.
also if you can get some better pics of the hoses for the propane and propane accessories
Old May 18, 2008 | 10:58 PM
yea it can be built for larger pots and always add your bigger ones later
Old May 18, 2008 | 11:05 PM
also is the hose anything special..i think i see how the hoses work..steel braided lines would look sweet ryan
Old May 18, 2008 | 11:17 PM
truckmann's Avatar
The hoses just need to be rated to carry propane. I actually have a couple like in the pictures with the regulators on them. Steel braided would look nice!
Old May 18, 2008 | 11:24 PM
hey man ill tell what ill do..this week or this weekend when i get some time, ill go to enid and go to atwoods..they gotta lotta cool stuff i think i can use..ill try to get a price on some caster wheels, a winch, cable and stuff for the cables, i gotta place i can go look for some angle iron and square tubing..atwoods also has metal too..ill try to get a you a ballpark price for some of this and see what you wanna do..i know this will be simple to build and i think i can make it bit cooler lookin than those...i gotta soft grinder pad that i will go over everything and just clear coat it..gives it a cool look i think
