Will 1500 leaf springs fit a 2500hd?
Old Sep 25, 2012 | 09:46 PM
zeake's Avatar
Default Will 1500 leaf springs fit a 2500hd?
Will 1500 leaf springs fit a 2500hd? I am thinking about swapping so I can ride on the airbags.
Anyone done this?
Old Sep 26, 2012 | 11:38 AM
1FastBrick's Avatar
Custm2500's Rude Friend
NO.... I believe they might physically be different in size. They may fit, but your putting a lighter spring rated for a lighter load. The 2500HD is a much heavier truck all the way around.
If it's just to lower, do it at your own risk. If your putting any kind of weight including multiple passengers, DON'T DO IT!!! If the Spring Fails, your going to be in a world of hurt.
What about removing a leaf from the pack??? Doesn't an HD have a large stack of like 5 leafs???
Old Sep 26, 2012 | 01:08 PM
zeake's Avatar
I am adding helper bags also. I figured they could take most of the weight. I really should leave it along. Safety of the issue I dont think would be a problem because of the bags. I have thought about taking the bottom leaf out. I am just not sure how to do that without scewing up the srpings.
Old Sep 26, 2012 | 03:23 PM
xx_ED_xx's Avatar
you could, are you trying to lower it or?
Old Sep 26, 2012 | 03:27 PM
zeake's Avatar
Lower it a little make it ride better. On my other truck I could let the air out of the bags back under a trailer and air the bags back up. Very conveniant.
Old Sep 26, 2012 | 07:20 PM
moregrip's Avatar
what a rush!
Yes...all day....check my old posts....been running 1500 springs for 5+ yrs
Old Sep 26, 2012 | 07:29 PM
moregrip's Avatar
what a rush!
https://www.performancetrucks.net/fo...s-pics-378253/
Old Sep 26, 2012 | 07:51 PM
zeake's Avatar
Thanks more grip
Old Sep 26, 2012 | 08:29 PM
1FastBrick's Avatar
How many miles on your setup in 5 years???
Old Sep 26, 2012 | 09:15 PM
moregrip's Avatar
what a rush!
maybe 10k.....more or less. When I did the mod I still drove her quite a bit.
zeake.....no worries brother.....check out diesel place forum for others who have done the mod for additional input
