took my Dmax to the track today
#26
Jody
#30
The big help for me was starting with a decent tune like Nicks as you mentioned, and then making small changes and datalogging in a consistent manner. What I did was found a deserted road near my home where I could make a 0-100 mph wot run safely without traffic or side streets, homes, etc. Then I did a 4wd launch at the same rpm everytime, going the same direction, starting at the same place, etc. to limit variables. I broke down 0-60 mph, 60-80 mph, 80-100 mph, and 0-100 mph out of a single 0-100 mph run. The EFI Live datalogger gives real time in seconds to the thousandths, and is very accurate. It is real easy to see if a change you made helped or hurt, and where in the run it helped or hurt. Try not to make too many changes at once so the results don't get skewed. The above is for performance changes. If you leave the cruise and low throttle areas along driveability is a non-issue. The other thing people are looking for is mileage, so datalogging timing, pulse width, commanded mm3, etc. at cruising speeds will help a lot. Try small changes in timing, boost, etc. and see how the mileage goes. I will say, I haven't found much to help in this area as well as just driving with a light foot.
Jody
