pressure reief valve shimming
Old Oct 26, 2006 | 12:21 PM
pswanney's Avatar
Question pressure reief valve shimming
Does anyone have any info/how to available on shimming the fuel pressure relief valve on an 05 LLY. thanks.
Old Nov 9, 2006 | 11:16 AM
TchargedLS1TA's Avatar
Not a good idea on a DMax.. You'll blow you're rails for sure. Best bet is a pressure box, either from Edge or PPE
Old Nov 9, 2006 | 08:33 PM
TIM Z's Avatar
11 sec. Truck Mod
Please explain why you would want to do this. I see PPE sells A fuel shim kit.
Old Nov 9, 2006 | 09:00 PM
All it does is keep your pressure relief valve for your rail closed to a higher pressure so your injectors spray more fuel. It can be done to the Cummins as well, but you increase wear on the injectors and injection pump, plus run the risk of cracking your rail or blowing up an injector..
Old Dec 27, 2006 | 01:23 AM
That is false.
It fixes the rail psi loss problem on the LLY ensuring you don't set a 1093 code when pulling out to pass. A 1093 code limits you to 2K RPM and can be very dagerous in a passing situation. The only other fix is to install lift pumps and make sure you change your fuel filter often. Many people have shimmed the rail and had great results. I have never heard of a failure related to shimming a rail, although it "could happen". A failure is very unlikely. Some people have plugged the relief with a PPE kit and added a second CP3 without issue.
Old Dec 27, 2006 | 10:12 AM
Originally Posted by Olson
That is false.
Why risk a few thousand $ in injectors when a simle $400 fueling box can do the same thing without raising pressures to unsafe levels. Its a good mod, dont get me wrong, but its better left for people who are racing or sled pulling only..
Old Dec 27, 2006 | 05:23 PM
TIM Z's Avatar
11 sec. Truck Mod
What type of "fueling box " are you talking about? Please elaborate.
Old Dec 27, 2006 | 11:36 PM
2000SIERRA's Avatar
I'm not sure what he means by "fueling box" but adding more fuel to the duramax without pumps or shims is what causes the 1093 code to come up. Shimming the valve is the cheap way to fix the problem, most people even shim them when they have lift pumps. I have twin Kennedy pumps with no shim and still can get a 1093 every now and then, so I plan on shimming the valve soon.
I don't think you should have a problem with the hypertech, but if you start building big tunes now the EFI live is out for the LBZ, you are going to want to shim and add pumps.
Old Dec 28, 2006 | 10:23 AM
Like the ones I mentioned a few posts earlier. Hell, if you want to get real cheap, get Don Morrisons Hot Box for $300.. Quick and easy 65 hp
Old Dec 28, 2006 | 02:47 PM
TIM Z's Avatar
11 sec. Truck Mod
???? ARE you calling the "EDGE" and "PPE" a fueling box?? If thats the case why didnt you just call em what every one else does, Tuning modules/programmers. To me a "fueling box" would be a Fuel Injector Pump like on a Cummins .
