picking up 75 extra hp???
Old Dec 16, 2011 | 12:54 PM
gotmud2178's Avatar
What would be a better head in the price range? I would really like to get the AFR's but man there $$$$
Old Dec 16, 2011 | 02:39 PM
jrmchevyman's Avatar
Look into PRC heads or maybe WCCH (west coast cylinder heads).
Old Dec 16, 2011 | 05:05 PM
pewterliftedz's Avatar
Look into a texas speed h&c package. Or even sdpc
Old Dec 16, 2011 | 05:28 PM
Beatdown Z's Avatar
Laid Back
Those are the same Patriots I have on my truck. Made a big difference, from off-idle to redline. I went from running a 14 flat in 2wd on bald 35's(measured 33.5) to 13.78 on 37's running in 4wd.
I would definitely contact Richard at WCCH though, as he does great work and has good prices.
Old Dec 16, 2011 | 06:37 PM
sand man's Avatar
a cam will give you that power every time you step on the gas,
the N2O is a good choice , but id go cam first
Old Dec 18, 2011 | 08:43 AM
gotmud2178's Avatar
I have been looking around and come to find out that my truck is factory rated at 300 and 360 at 9.4:1 compression. If I changed out the head with a set that were 59cc's what would my compression ratio go to assuming my factory ratio is 72cc.
Also I should have no problem picking up more than 75hp if this engine is rated at 450. Im thinking that a head swap, cam, lt and a tune and I should be pretty close to this engine. Am I wrong?
GM Performance Parts - 19171049 - GMPP LSX376 450 HP Crate Engine
Old Dec 18, 2011 | 09:04 AM
MikeFSKSpeed's Avatar
LS1Tech Sponsor
Originally Posted by Nitrous Express
i can get you 75hp or more if you would like for $369
Ive been keeping the mainline kits in stock juuuuust for that purpose!
Old Dec 18, 2011 | 02:25 PM
Beatdown Z's Avatar
Laid Back
Your c/r with 59cc chamber's will be around 10.8:1.
Many people have done setups just like the one in my sig, which is very close to what you're wanting to do. They all dyno around 400/400. So factor in about 18% drivetrain losses and that put the flywheel power/torque around 470...
Old Dec 18, 2011 | 06:30 PM
gotmud2178's Avatar
Do you think there would still be an 18% loss with the standard tranny? I would think it would be a smaller loss in power.
Old Dec 18, 2011 | 08:48 PM
About +10RWHP more if you have a manual vs auto on the dyno, This is the average on Silverados, G8's, 5th gen camaros, vettes, etc..
The above has been said from a few tuners/dyno guys on diff forums.
