Interesting read on diesel break-in
I guess this can be said for gas engines as well?
To a certain extent, diesel motors have inherently higher cylinder temps then a gas motor due to the high compression they run. The rings they talk about are used in alot of high performance motors these days so I would venture to say alot of what the article says can be carried over into the gas motors as well. I dont think the oil glazing they are talking about is as much of a problem in gas motors but the break-in procedure is nearly the same. Varrying loads help seal the rings in all motors.
Ah,, Cody... ya readin up on your new Dmax i see??????? :devil:
I gotta be informed ready to spend mod money when it hits the driveway:devil:
(Post 3752875)
(Post 3752875)
Originally Posted by NoChrome
(Post 3752913)
I havent seen too much stuff for the new diesels, how do you plan on getting by the particulate filters? can you tune the faults out? got a way around an emissions test?
the particulate filters suck.... but theyre not that hard to "deal with"
ex. deal with requires use of sawzall or hack saw :D actually the NHTSA is still behind on a date when it will actually be emissions testing them... and it will have the same exemption of the first few years from emissions tests.... :judge: plus most aftermarket exhausts get rid of the particulate filter :D high flow intake, down pipe, exhaust, and a good tune... if you decide you need a lil more you can go mix of propane and NČO and you will have plenty of power.... not to mention you put a littl more injector in it and you can smoke anybody... Literally on my 6.0 SD if a ricer pulls up bumpin his music with his hub cap spinners i just floor it and usually can fill his interior up with nice cancer causing black diesel smoke :angel: |
(Post 3752913)
Or if the cluster holds the mileage like the NBS trucks then Ill get a second cluster for when it goes to the dealer so it will have a low regen count and low mileage to match. I doubt Ill get too crazy with the truck for a while though so Im not too worried. Atleast here in TX inspection of a diesel only consists of a safety inspection, IE seat belts, brakes, etc no emissions till 2010 I believe. |
