Differences between LLY and LMM
Old Jan 22, 2008 | 09:15 PM
  #21
1slow01Z71's Avatar
Tin Foil Hat Wearin' Fool
Originally Posted by nekkidhillbilly
well actually i the lly can be modded alot more than the lbz but the lbz has the 6 gear ally oppesed to 5 but you can do the suncoast tranny and have it which you will need with big power anyhow
How do you figure the LBZ has stronger rods and a better block among other things. The 5 speed allisons can be converted to a 6 speed with the suncoast kit.
Old Jan 22, 2008 | 10:36 PM
  #22
fastrt's Avatar
11 Second Truck Club
are you 100% sure on that? the 06 lly and lbz are i...dentical. the tune is the only diff. when they made the d-max they had to detune it to the 310 hp version. and in 06 they gave them the go ahead to do 360 hp. the insides are the same in 04i-06 lly and 06 lbz. the 01-04 have the same short block as the 04i-06, but diff. head design.
Old Jan 23, 2008 | 09:04 AM
  #23
1slow01Z71's Avatar
04.5-05 are the same motor LLY, 06 the LLY and LBZ are NOT the same with just a different tune thus the statement the LLY has greater power capabilities then the LBZ is NOT true either. The 06 LLY shares the same block as the LBZ but thats where the similarities end. The LBZ has beefed up rods, different pistons, lower compression, revised turbo the list goes on. The LLY got all the emissions crap over the LB7 along with the variable vane turbo.
Old Jan 23, 2008 | 01:25 PM
  #24
fastrt's Avatar
were are you getting info that the lbz has stronger internals than a lly? I have been in a lot of lb7's and a few lly's both 05 and 06's and they have the same parts in the lower end. It is hard to think that gm is going to beef the short block for 50 hp. the 06 lly and lbz should be the same. besides the bottom end of a 6.6 is damn near bullet proof on any version.
Old Jan 23, 2008 | 01:53 PM
  #25
kbracing96's Avatar
I am
How about this.....
http://www.thedieselpage.com/duramax...ewsrelease.htm
The comprehensive list of changes and upgrades to the 2006 Duramax 6600 includes:
* Cylinder block casting and machining changes strengthen the bottom of the cylinder bores to support increased horsepower and torque.
* Upgraded main bearing material increases durability.
* Revised piston design helps lower compression ratio to 16.8:1 from 17.5:1.
* Piston pin bore diameter increased for increased strength.
* Connecting rod " I " section is thicker for increased strength.
* Cylinder heads revised to accommodate lower compression and reduced cylinder firing pressure.
* Maximum injection pressure increased from 23,000 psi to more than 26,000 psi.
* Fuel delivered via higher-pressure pump, fuel rails, distribution lines and all-new, seven-hole fuel injectors.
* Fuel injectors spray directly onto glow plugs, providing faster, better-quality starts and more complete cold-start combustion for reduced emissions.
* Improved glow plugs heat up faster through an independent controller.
* Revised variable-geometry turbocharger is aerodynamically more efficient to help deliver smooth and immediate response and lower emissions.
* Air induction system re-tuned to enhance quietness.
* EGR has larger cooler to bring more exhaust into the system.
* First application of new, 32-bit E35 controller, which adjusts and compensates for the fuel flow to bolster efficiency and reduce emissions.
* The Duramax 6600 also has a new intake air heater to reduce smoke and emissions during cold or light-load driving. The system features a 1000-watt grid heater located in the air intake duct, which is triggered automatically by the engine controller. It heats up the incoming air to speed warm-up of the engine.
Old Jan 23, 2008 | 02:54 PM
  #26
fastrt's Avatar
and that just said that the 06's are the same. not that the lbz has a beefier bottom end than the lly in 06. the difference is the year then. cool. thanks for that info. i have not compared a 06 piston to a 05 lly but you can bet your *** i will just to see if there is a noticeable diff. the lb7 and lly insides look the same from 01 to 05. so still, the tune is the diff on the 2006's.
Old Jan 23, 2008 | 04:10 PM
  #27
1slow01Z71's Avatar
Get to reading
http://www.dieselplace.com/forum/showthread.php?t=66077
http://www.dieselplace.com/forum/showthread.php?t=67521
The 06 LLY has the same block as the new LBZ, but without the enhancements.
Im just going off what Im reading on various diesel sites. I could really care less in the end since my next truck will most likely be an LMM due to the new job Im taking I will need a heavy duty truck.
Chewy07
Nov 14, 2015 09:46 PM
wickedRCSB
Oct 30, 2015 09:45 PM
Staggered 02
Oct 9, 2015 05:19 PM
gmcyukon
Oct 5, 2015 06:20 AM
sTNT971
Sep 26, 2015 06:27 AM
