Black Smoke?
#42
GFYS and STFU
What's the deal with washing out the rings on a Diesel? If you run a gas engine too rich you'll wash out your pistons, pressurize your crankcase and possible blow your oil pan out right? What's stopping that from happening with the Diesels since they are over fueling it to death?
#43
How do I change this text
I think you would see cylinder wash at the point of miss-fire...
Isn't that true with gas too?? As long as the cylinder fires, it doesn't matter how rich it is, it won't wash the cylinder?????
#45
Don't forget they have compression ratios in the teens, plus diesel engines inject fuel over 20,000 PSI... I "THINK" that the black smoke is a characteristic of the fuel, it will burn black if the proper fuel air mixture is not kept. (although the ratio is changine all the time)
i think, but dont quote me on this, is that with the high compression, and obscene boost pressures, diesels tend to have much tighter rings, and much harder cylinder walls, therefore even excessive over fueling wont necessarily wash down a cylinder wall on a diesel
#46
GFYS and STFU
Even if the cylinder walls are washed down on a diesel the fuel will just relubricate it anyways so the walls will always have something on them right? I mean you can't wash out a lubricated surface with a lubricant right?
That makes alot more sense to me, now I'm wondering what the carbon build up on pistons would look like on a diesel if any. I'm sure the headers and exhaust would look pretty nasty too!
#47
#49
#50
The viscosity of diesel fuel in far to low, plus if doesn't have all the additives found in normal oil...
As for carbon, there is usally some much built up, you can't get the piston out of the bore until you "Decarberize" the cylinder wall.
