Big Brake Upgrade for 3/4Ton GMT800 ??
Old Jan 30, 2023 | 04:44 PM
  #21
arthursc2's Avatar
What you said was...
The SSBC is an aftermarket Brake caliper not OE... and yes it does work with the OE Brake rotor.
Originally Posted by arthursc2
Which is still a stock diameter rotor, which is what I said in my post lol
Honestly, nothing but the OE brakes fit under the PYO's. I absolutely agree that PYO's for lyfe, but you can only run OE diameter under them. I can't even keep them when I go SAS because the Dodge axle uses brakes large enough to require 17s. Oof
Seems to me like I identified that only OE diameter rotors fit under the PYOs, which is exactly what I said and exactly that SSBC says when they say their 3 piston calipers *must be run with OEM size rotors*
So.... we arguing just to argue? You got some other trick up your sleeve to tell me that somehow bigger brakes fit under the PYO's and other 16" wheels? Aftermarket caliper =/= bigger brakes. No leverage increase. Clamp force may be better, I'd have to know piston sizes to do the math, but there is no increase in leverage. Bigger rotors do not fit under PYOs, which I said 3x now.
Old Jan 30, 2023 | 04:53 PM
  #22
1FastBrick's Avatar
Custm2500's Rude Friend
Talking
I am just arguing because I like to be right!!! Even if its just a technicality...
Old Jan 30, 2023 | 07:45 PM
  #23
shakenfake's Avatar
Shlumpt
5 Year Member
I don't know... Sounds like it would be more cost effective to just throw them out...
At this rate the playboy mag is just going to be pictures of me
Old Jan 30, 2023 | 07:49 PM
  #24
1FastBrick's Avatar
Thumbs down
SickSilverado
Oct 13, 2015 03:06 PM
pewterliftedz
Feb 18, 2010 04:04 PM
dug
14
Nov 6, 2007 01:32 PM
Z1500
May 19, 2005 11:25 AM
