2012 d-max?
Old Feb 16, 2013 | 08:00 AM
darnie's Avatar
Originally Posted by 1FUNZ71
His LML will never be tuned EFI unfortunately. I wish it weren't the case. I would love to get a tune on mine.
why's that? i though that you could tune any newer truck with it? or are all the pcm's locked?
Old Feb 16, 2013 | 10:46 AM
kbracing96's Avatar
GM made it so you can physically not read the PCM out of the OBD2 port on the LML and new trucks. So EFILive can not read the current stock tune out of the PCM to modify it. With out that they can not support the 2011 and newer Dmax trucks. They have said over and over that they will NOT be supporting these trucks because off this issue.
Old Feb 19, 2013 | 09:34 AM
Chevy Cowboy's Avatar
Piss Pumps for Sale
From: Moncton, New Brunswick, Canada, The True North Strong and Free!
is EFI the only company that will not be supporting them? Or is this an industry wide sort of thing?
Old Feb 19, 2013 | 10:49 AM
1slow01Z71's Avatar
Tin Foil Hat Wearin' Fool
HPT and efi wont be supporting the LMLs. Your best bet is an H&S tuner.
Old Feb 19, 2013 | 11:42 AM
gamble686's Avatar
If it is completely locked down why can H&S do it? I know edge paid out to get the code to crack it. Did H&S do the same?
Old Feb 19, 2013 | 04:10 PM
kbracing96's Avatar
There is no "code to crack" You simply physically, can NOT read the ECM through the OBD2 port. You would have to disassemble the ECM and read directly off the chip. You can flash to it (what H&S does), but not read it. You would have to get a stock file from the GM data base, modify it and then flash it to the ECM. This violates the terms of use agreement with the GM data base and EFILive said they want no part of that. EFILive's WHOLE premise is you READ out the stock tune and modify it and then flash it back in. This is NOT possible with the new ECM's GM is putting in these truck, so therefore they are not supporting them. This is what was explained to me from EFILive.
Old Feb 19, 2013 | 05:34 PM
tank454's Avatar
There may not be EFILive, but DuramaxTuner.com is working on some pretty good tunes for it. Based on their EFI tunes I've seen in the past, I think their LML stuff will be pretty sick.
LML Testing Continues | Facebook
Old Mar 8, 2013 | 10:59 PM
darnie's Avatar
well apparently once i get the new tranny and converter finished i will have to run him.... Note to him dont talk trash to the GF prob install tru-trac for good measures
Silver8ado
13
Oct 21, 2024 09:09 AM
OVOAustin
Sep 15, 2015 08:32 PM
Silver8ado
Sep 14, 2015 06:35 PM
rednekferlife101
Sep 14, 2015 05:27 PM
Gmc_sierra
Sep 13, 2015 10:02 PM
