04 CCSB 2500HD 6.0 Need more speed
#21
I have a set of longtubes I plan to put on and delete the inside of the cats,hopefully I might gain some torque hopefully ? Then at some point around a 3,000 stall,a small cam,and possibly a set of 6.2 heads not sure if they will help with my combo and lack of torque anyway ?
#23
#24
I ended up installing some pacesetter longtubes,3" Y-pipe into single 3" into 50 series flowmaster and single rear side exit,deleted the cats.I didn't notice any more power at all about the same.I thought I would pick up some power from the longtubes and gain some torque from going true dual 3" to single but no? WTH,cam upgrade and around a 3000 converter in the future. By doing all this would I pick up decent power with some L92 heads with the 90mm intake,and tb.Over the 317 heads ?
#25
#27
I don't know much on heads so couldn't tell you how they'd perform, haven't heard of anyone swapping them onto their projects though. The headers are a top-end gainer, along with that LS9 cam. I was ready to do that cam swap (I could get one off my tuner for cheap) but after I looked into it it wasn't worth it unless you wanna go fast. It's a top-end gainer as well, doesn't peak until about 6,300, not too ideal for a truck. It'd all definitely provide top-end performance but I can't tell you anything other than that, haha
#28
Not sure who else has done this ?
I just found out that the 4l80 trans converter locks up at full throttle in 2nd gear which sucks IMO,so I pulled up my old truck 5.3/4l60 tables in my hptuners software and matched those TCC tables in my 04 6.0/4l80.It runs ALOT better pulls harder for sure,not such a pooch anymore.
#29
