maf or SD on 07-13 lsa build
Truck Sponsor
OP: On most ECMs of that year, the IAT sensor is Pin 37 or 62 (tan/black wire). If you tell me your VIN I can tell you exactly. On the MAF connector it could be pin B or D (still a tan wire).
Ford, if you look at the upgrade options for your PCM it will tell you 2 or 3bar. If yours is a cable TB, its most likely 3bar in which case the ZL1 sensor should be fine, although do you really expect to be pushing 15psi+ of boost with that little blower? The later 04-07 PCMs are mostly only 2bar.
If you need tuning assistance I would be glad to help
Come Get Some!!
I seriously doubt I will push more than 14 psi, but the point was to use my existing ZL1 MAP sensor(s).
I have a LS3 style card maf integrated into my intake. I used a polynomial regression to convert the MAF calibration to the correct columns since the hz labeling is different in EFI Live. It pays to keep a MAF around as an option in an emissions state so the inspectors don't bitch.
The 2 bar option on the GEN 4 computer can be nice but you can totally do everything with the regular VVE editor. They allow you to use the stock VVE like a 2-3 bar setup with a simple change of the MAP axis.
Either way works and many computers don't have a 2 bar OS upgrade anyway.
Mercier
05-04-2016 11:35 PM
Jojoman01
24
05-03-2016 05:07 PM
